B BlueinTulsa New Member Nov 14, 2019 1 0 1 Tulsa, OK Nov 14, 2019 #1 Nov 14, 2019 #1 Anyone familiar with a liquid you flush thru your radiator to repair head gaskets
wmburns SN Certified Technician Aug 14, 2009 5,892 514 204 Houston Texas Nov 14, 2019 #2 Nov 14, 2019 #2 Yea. Don't do it. It doesn't work plus it does more damage than it solves as it coats the inside of the block and radiator.
tsemmett Active Member Jul 2, 2019 276 33 38 US Nov 18, 2019 #3 Nov 18, 2019 #3 The only thing you should ever add to the radiator is coolant/water; all these stop leaks and HG fixes are just going to clog up your radiator/heater core/block. You'll end up with an even more costly repair in the long run.
