head gasket?
  • Thread starter Thread starter 302fordracer
  • Start date Start date Sep 16, 2007
302fordracer
738
Vancouver, WA
Sep 16, 2007
  • Sep 16, 2007
I have been fighting an overheating issue and I did some testing today looking for the problem..I bought a craftsman infrared temperature gun and took the temperature at the header flanges. I made sure to keep my hand very steady and took the temperature at the same spot for each cylinder...my results; cylinder 1 ran (after car reached full operating temperature) around 230-235 degrees while every other cylinder was around 310-315...do you think that this indicates a blown head gasket? and could this be the source of my overheating even if I am NOT losing coolant?
302fordracer
738
Vancouver, WA
Sep 16, 2007
  • Sep 16, 2007
No one has any input???
fastford91
254
Niagara ,Ontario, Canada
Sep 16, 2007
  • Sep 16, 2007
if its a head gasket there should be white smoke coming out the exhaust and a sweet smell depending on how big it is! i dont know anything about the tool you bought!
302fordracer
738
Vancouver, WA
Sep 16, 2007
  • Sep 16, 2007
that would be if i were burning coolant but i am curious because i know that you don't necessarily lose coolant with a bad head gasket.
rockytoohot
48
  • Sep 16, 2007
Does your cooling system pressurize very quickly after you start the engine? Do you see a never ending stream of small bubbles coming up through the rad with the cap off? These are two indicators of a blown head gasket and are very easy to check.
parchisi
519
New Mexico
Sep 17, 2007
  • Sep 17, 2007
I personally have never heard of the test that you ran, so I'm not saying that it isn't legit. But I'd just run a compression test. If that checks out ok, I'd start lookin' elsewhere.
ninety15.0
1,336
  • Sep 17, 2007
I understand where you are coming from with this test. I think that if there were a HG problem....coolant in that cylinder would cause lower temps. Especially considering the large difference in temperature between that cylinder and the rest....not to mention that temperature is just above a normal coolant temp. I would do a comp check and leak down test. Hopefully those will tell you the rest of the story. Good luck
302fordracer
738
Vancouver, WA
Sep 17, 2007
  • Sep 17, 2007
I don't have the necessary equipment for further testing but it goes in thursday to my trusted mechanic...hopefully he will be certain about it before I lay down the time and money on this project..
PUNISHER RACING
1,124
FORD CITY, PA.
Sep 17, 2007
  • Sep 17, 2007
Have you tried a thermostat maybe its sticking ,you need to pressure test the cylinders to find out if you have a bad gasket.
302fordracer
738
Vancouver, WA
Sep 18, 2007
#10
  • Sep 18, 2007
  • #10
everything in the cooling system is brand new...new thermostat new radiator new fan fresh coolant and oil...I'm pretty sure it needs a gaket but I want to be positive...
302fordracer
738
Vancouver, WA
Sep 18, 2007
#11
  • Sep 18, 2007
  • #11
if anyone has a set of gt40 irons now is the time for me to do that upgrade...lol
Flavadave4
1,044
21
49
Utica, NY
Sep 18, 2007
#12
  • Sep 18, 2007
  • #12
Was you fan running during this test?
302fordracer
738
Vancouver, WA
Sep 18, 2007
#13
  • Sep 18, 2007
  • #13
yep..
D
Engine how fast would an engine overheat with zero coolant
  • dqureshi06
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 8, 2024
Mustang5L5
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
