Head Gasket?
rangerboy101
310
20
28
Inwood, WV
While on my way into work this morning I ran into a small issue. I was cruising around 50mph in 4th and as I approached the shop I slowed down, shifted into 3rd, and checked my rear view mirror to see a huge cloud of white smoke. First thought was "wtf is going on? It's too early for this shi t." Luckily I was right in front of work so I just coasted it into the parking lot and shut it off. I got out and popped the hood and the first thing I noticed was a hissing sound from one of the coolant hoses. No major leaks or any puddles of coolant. A couple of car guys at the shop all said it was the head gasket. What do you guys think? I started the car once more for roughly 30 seconds around 3:30 today(this all happened at 6:30 this morning). I loaded up the car on my trailer and towed it home and she's just sitting in the garage now. I haven't done anything else to it as I'm afraid to really mess anything up. So what's the diagnosis? Head gaskets?
White cloud is a sure sign of moisture in the oil. Smell your coolant. Does it smell like exhaust? Also drain the oil like mentioned before.
Don't guess - diagnose!
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
let it cool down (obviously) and pull the rad cap off. Then fire it up, if it blows coolant out of the rad, you have yourself a blown hg. Sometimes a hg leak is really small and it might take a couple days to mix with the oil to definatively tell that it is a blown hg.
However now is a great time to upgrade the heads! lol
