Head Flow Data In CFM-Source: http://users.erols.com/srweiss/tablehdc.htm#Ford
Intake Flow Numbers:
Intake – Average CFM
Stock Upper -198
Stock Upper - 192
Stock Lower - 150
Stock Lower - 158
Ported Lower - 205
Stock HO - 158
Ported Stock HO - 200
Saleen/Vortech - 180
GT40 - 205
GT40 Upper - 223
Cobra - 205
Cobra Upper - 271
Explorer - 205
Ported Explorer - 229
Stock GT40 Lower - 219
Ported GT40 Lower - 272
Stock SN Cobra Upper - 248
SN Cobra Upper - 261
Ported Lightning Lower - 302
Performer - 220
Ported Performer - 231
Performer - 209
Performer RPM I - 230
Performer RPM I - 232
Ported RPM I - 277
TF Street Heat - 245
TF Track Heat - 265
Trick Flow R - 290
Victor 5.0 - 282
Ported Victor 5.0 - 317
Super Victor 351 - 320
Stock Stealth 351 - 233
Ported Stealth 351 - 263
Thanks to Tom Moss (tmoss) for much of the intake information, he was very helpful.
Throttle Body CFM Flow Ratings:
Stock 5.0L 60 MM - 526 CFM
SVO 65 MM - 540 CFM
Accufab:
65 MM - 664 CFM
70 MM - 787 CFM
70 MM - 896 CFM (Race version)
75 MM - 924 CFM
75 MM - 1045 CFM (Race version)
80 MM - 1142 CFM
85 MM - 1322 CFM
90 MM - 1369 CFM
105 MM - 1550 CFM
Holley:
65 MM - 750 CFM*
70 MM - 790 CFM*
75 MM - 840 CFM*
80 MM - 892 CFM*
*Information given by Tech Rep.
BBK:
70 MM - 726 CFM
Edelbrock, Ford Racing and Proffessional Products have no cfm information after calls/emails.
Information to keep in mind when picking out a throttle body for your application:
A 300 cubic inch engine (302 c.i.) flows 521 cfm at 6,000 rpm.
A 330 cubic inch engine (331 c.i.) flows 573 cfm at 6,000 rpm.
A 350 cubic inch engine (347 c.i.) flows 600 cfm at 6,000 rpm.
With the above information from Accufab's website, you can see that the aftermarket throttle bodies offered flow much more than your engine can breath (302-347). Those cfm ratings are even given with NO restrictions and of course our engines all have restrictions, via our heads, cam, intake packaging. An actual running engine flows somewhere in the neighborhood of 200-400 cfm with some rough math. The aftermarket throttle bodies flow two times this amount.
In short, be careful on picking 'too big' of a throttle body for your car. An application with boost (forcing air) allows for you to efficienty select a bigger throttle body, although N/A engines do not.
If you've got a throttle body that delivers 100% of the peak air requirements of your engine when the throttle plate is fully open, you have control of the air throughout 100% of the throttle position range. If you go to an oversized TB that delivers 100% of the air that your engine can consume while the throttle plate is only 60% open, you have given up usable throttle-control range for no advantage.
Stock Throttle Body and MAF sizes:
1986 - 58 mm TB
1989-1993 - 58 mm MAF and 60 mm TB (not Cobra).
1993 - 70 mm MAF and 65 mm TB (Cobra).
1994-1995 - 60 mm TB (Cobra's included).
1996-2001 SOHC - 80 mm MAF and 65 mm TB.
2002-2004 SOHC - 85 mm MAF and 65 mm TB.
1996-2001 DOHC - 80 mm MAF and Twin Round 57 mm TB.
2003-2004 DOHC - 90 mm MAF and 56 mm TB.
Gear Calculator:
http://www.allfordmustangs.com/Detailed/608.shtml
Reference with T5 transmission/stock tire size/16in. wheel, in 5th gear cruising rpm at 70mph (Interstate Speed):
2.73:1 - 1696 RPM
3.08:1 - 1914 RPM
3.27:1 - 2032 RPM
3.55:1 - 2206 RPM
3.73:1 - 2318 RPM
3.90:1 - 2423 RPM
4.10:1 - 2548 RPM
4.30:1 - 2672 RPM
4.56:1 - 2834 RPM
Fuel Injector Selection:
Injector HP Ratings: divide flow rating by .5 and multiply the result by the number of injectors. The following examples use a 100% duty cycle. These ratings are for N/A engines at the flywheel.
Example:
19 lb injectors/.5 = 38 - 38 x 8 = 304 HP
24 lb injectors/.5 = 48 - 48 x 8 = 384 HP
30 lb injectors/.5 = 60 - 60 x 8 = 480 HP
36 lb injectors/.5 = 72 - 72 x 8 = 576 HP
42 lb injectors/.5 = 84 - 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP for 19lb injectors
385 HP x .85 = 326 HP for 24lb injectors
480 HP x .85 = 408 HP for 30lb injectors
576 HP x .85 = 490 HP for 36lb injectors
672 HP x .85 = 571 HP for 42lb injectors
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
The above information is courtesy of jrichker!
Static Compression Calculator:
There are many factors that contribute to static compression:
Bore, Stroke, Number of Cylinders, Combustion Chamber Volume, Piston Volume, Head Gasket Thickness, and Deck Volume for basic calculations.
Static Compression Example using Compression Calculator Link
Bore - 4.00"
Stroke - 3.00"
Number of Cylinders - 8
Combustion Chamber Volume - 58cc
Piston Volume - (-4cc, dished piston)
Head Gasket Thickness - .039"
Deck Volume - .010"
Compression is 9.581:1
Stock Upper -198
Stock Upper - 192
Stock Lower - 150
Stock Lower - 158
Ported Lower - 205
Stock HO - 158
GT40 - 205
GT40 Upper - 223
Cobra - 205
Cobra Upper - 271
Explorer - 205
Performer - 220
Performer - 209
Ported RPM I - 277
TF Track Heat - 265
Trick Flow R - 290
Victor 5.0 - 282
SVO 65 MM - 540 CFM
Accufab:
65 MM - 664 CFM
70 MM - 787 CFM
75 MM - 924 CFM
80 MM - 1142 CFM
85 MM - 1322 CFM
90 MM - 1369 CFM
105 MM - 1550 CFM
Holley:
65 MM - 750 CFM*
70 MM - 790 CFM*
75 MM - 840 CFM*
80 MM - 892 CFM*
BBK:
70 MM - 726 CFM
1986 - 58 mm TB
Gear Calculator:
2.73:1 - 1696 RPM
3.08:1 - 1914 RPM
3.27:1 - 2032 RPM
3.55:1 - 2206 RPM
3.73:1 - 2318 RPM
3.90:1 - 2423 RPM
4.10:1 - 2548 RPM
4.30:1 - 2672 RPM
4.56:1 - 2834 RPM
Example:
Bore - 4.00"
Stroke - 3.00"
Deck Volume - .010"
