  • SN95 4.6L Mustang Tech
Head Questions.
  • Thread starter Thread starter ky_kneedragger
  • Start date Start date Mar 13, 2008
ky_kneedragger
58
ky
Mar 13, 2008
  • Mar 13, 2008
Hey Guys, I have a 2000 GT with a warped valve, (long story) Anyway i found a set of heads at a pick a part today. They are RF-2L1E-6090-C20B. Will these fit with no problems on my engine? They are in great shape. They are on a truck 5.4. Anything I should look for? Combustion chambers the same and so forth? Everthing bolt up?
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 13, 2008
  • Mar 13, 2008
As long as they are windsor PI heads then yes you should be just fine. I used windsor PI heads from a 5.4 on top of my 2000 GT.
Bill
ky_kneedragger
58
ky
Mar 13, 2008
  • Mar 13, 2008
Bill
do you remember what the cast #'s were??
ky_kneedragger
58
ky
Mar 14, 2008
  • Mar 14, 2008
i also got thinking about compression as well,any idea to find out the combustion chamber on these heads by using the cast numers?
the cast is RF-2L1E-6090-C20B
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 14, 2008
  • Mar 14, 2008
Sounds like Romeo heads to me, could be wrong. Windsor heads usually started with "pi"
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 14, 2008
  • Mar 14, 2008
PI heads are PI heads when it comes to combustion chambers. i woudl tend to avoid the older PI castings because they have the inferior spark plug thread design.
ky_kneedragger
58
ky
Mar 14, 2008
  • Mar 14, 2008
what do you mean by " the inferior spark plug thread design."?
ky_kneedragger
58
ky
Mar 14, 2008
  • Mar 14, 2008
they may be but doesn't romeo or windsor heads come pi? and on the front of the heads behind the timing cover they have pi stamped in them
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 14, 2008
  • Mar 14, 2008
yeah 2001+ romeo heads are PI, but their casting numbers start with RL or Rf or something. 99/00's start with PI. The thread design he was talking about are only improved in 2004 heads, more threads in the sp hole to eliminate sp blow out
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 14, 2008
#10
  • Mar 14, 2008
  • #10
exactly, the older PI heads had 4 threads holding the plugs in, hence why they like to come flying out on a regular basis. the newer PI heads have 8-9 threads, adn also use the updated spark plug with full length threads.
ky_kneedragger
58
ky
Mar 14, 2008
#11
  • Mar 14, 2008
  • #11
well i counted the valve cover bolts and they had 13 like my stock heads,but the cast number is RF-2L1E-6090-C20B. did the romeo heads have pressed on cam gears??? my windsor cams did. if they are romeo what would i need to run them besides the covers?
heyzuess
25
#12
  • Mar 15, 2008
  • #12
I think only the Windsors cams had pressed on cam gears.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 17, 2008
#13
  • Mar 17, 2008
  • #13
The windsors have pressed on cam gears the romeos are bolt on.
Bill
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
Oil galley in 4.6L head...where does it go?
  • droptop93
  • Oct 28, 2024
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2024
