Head removal :)
  • Thread starter Thread starter MikeR351w
  • Start date Start date Oct 20, 2008
MikeR351w
207
Wisconsin
Oct 20, 2008
  • Oct 20, 2008
Hello,
I have a 93 LX 5.0, with an auto trans. I am currently in the process of removing the drivers side head. I currently have the bolts to the header removed, the plug wires removed, the valve cover removed and the rear thermactor passage tube removed.
Question: If I just removed the 8 bolts that secure the head to the block, do I have to removed all the valve spring bolts and such? I have never got into an engine this far. Any help would be much appreciated. Also, I do know to remove and install the bolts in proper order with correct torque specs. Thanks!!!
:SNSign:
ls1beater4eva
334
mooresville
Oct 20, 2008
  • Oct 20, 2008
ok you first have to take off the air intake tube, upper and lower in take manifold , the ac and power steering the ac can be unbolted from the bracket and and just laid over to the side,and remember when u brake the head bolts free work from the center out top and bottom .
MikeR351w
207
Wisconsin
Oct 20, 2008
  • Oct 20, 2008
Thanks for the reply. I am already that far. I am removing the head because a bolt snapped off in the head while preparing for a Edlebrock RPM II intake. So I dont have to touch any of the valve bolts?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 20, 2008
  • Oct 20, 2008
You don't have to remove the rockers to take the head off, but it's a good idea to take them off and put them back on the right way once you have the head off. It's not very hard...you just have to follow a process of turning the engine over by hand until one valve is completely closed...then torque down that rocker, and so on and so on until they're all torqued. The push rods are gonna fall out of the heads if you don't take the rockers off...and it's wise to keep track of which pushrod went with which valve, so it's probably a good idea to take the rockers off first so you can be sure which rods go where. Get a small cardboard box and poke holes in it and number the holes per cylinder and stick the rods in so you know where they go when you're putting it back together.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 20, 2008
  • Oct 20, 2008
Very good info. Small information like this is good. I was gonna say, no, don't take the rockers off, but then when you pull the head off, the push rods will fall all over the place... Small things I forget...
302_Coupe didn't forget about this part...
+1 for 302_Coupe.
885.0conv
238
Phoenix, Az
Oct 20, 2008
  • Oct 20, 2008
I am in the process of putting new heads on mine but the bolts keep braking on me. I know the bolts for an 88 have 90 ft/lb but they have a different bolt. The head on the bolt is different. I do believe the 93's have a bolt with an integrated washer, correct me if I am wrong, they also have a different torque spec. The chilton/haynes manual should tell you, if you dont have one I recommend getting one.
btlfed91
42
STL
Oct 20, 2008
  • Oct 20, 2008
If you are going thru all of this anyway I would go ahead and put ARP bolts on and dont worry about it anymore.good investment if you ask me.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 21, 2008
  • Oct 21, 2008
Stock headbolts will work. I suggest ARP though, as stated.
You can remove the heads after removing just the head bolts.
  • dan50
  • Jul 18, 2026
dan50
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
