head spec's question
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Apr 23, 2006
M
MattTheBat83
203
  • Apr 23, 2006
if i have stock heads that may have been ported, how do i measure them to find out what they are?
txstang84
1,639
42
69
Tuscola, tx
Apr 23, 2006
  • Apr 23, 2006
what exactly do you mean by measure? valve size? comb chamber size?
if they are stock heads, you'll see date codes cast into the springed side of the head (under the valve cover), and more than likely a couple Ford emblems cast into them as well...
the actual casting number (i.e. E7TE, E6SE, etc.) will be cast into the underside of the intake runner-you have to take the intake off to see it-with a mirror if the heads are still bolted down.
if they're off the engine, look on the mating side of the head under the intake runner and you should be able to see what casting number they are
M
MattTheBat83
203
  • Apr 23, 2006
i wanted to know what cc's or cfm's they are, i don't know much about heads
txstang84
1,639
42
69
Tuscola, tx
Apr 23, 2006
  • Apr 23, 2006
well, stock heads (E7TE) are 62cc's nominal for combustion chamber, with a 124cc intake runner, and about a 50cc exhaust port (I think)...
as far as unported cfm's for stock heads, they're terrible...probably somewhere in the neighborhood of 175-180 for intake side @ 0.500"...exhaust flow probably about 110 @ 0.500". ported flow #'s are improved, but still not great...if you're looking for good flowing stockers, ck out a set of thumper heads. Using the stock valves that are backcut, with a 5 angle valve job, they flow significantly better-and are enough to put your 'stang into the 12's with modest bolt on's...and they only cost $600.
lemme try to find the weblink, and i'll post it...
txstang84
1,639
42
69
Tuscola, tx
Apr 23, 2006
  • Apr 23, 2006
here, try this one...
http://thumperoforangepark.com/
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
