Header bolts backing out... solutions?
  • Thread starter Thread starter SadbutTrue
  • Start date Start date Aug 25, 2008
First Prev 2 of 2
edgars23
80
Los Angeles Area
Aug 26, 2008
#21
  • Aug 26, 2008
  • #21
I can see how the Stage 8 bolts might not fit some headers...but I was able to get them on my Doug Thorley long tubes, after I torqued the bolts in place and but the locks on, they've never had to be touched again. They were expensive, but well worth the investment for me.
T
truck90278
382
Redondo Beach, CA
Aug 26, 2008
#22
  • Aug 26, 2008
  • #22
We're using header bolts from Totally Stainless, work great, won't back out and have a small washer so clearance isn't an issue
SadbutTrue
2,391
Thousand Oaks, California
Aug 26, 2008
#23
  • Aug 26, 2008
  • #23
I will say my header bolts are somewhat low profile. I might go pull one out and measure it, but I know the lone ARP header bolt that PAW gave me is a bit longer and I had to use washers for it.
Now that you describe them, I may in fact have the composite gaskets. So I guess I need to pick up some aluminum gaskets and some slightly nicer bolts. Are the Stage 8s in a class of their own or are there other ones that will help? I'm also slightly worried about those 'locks'... will I be able to get at all of them with my header pipes in the way? There is very little clearance on a couple of them.
iskwezm
4,159
20
79
Rowland Heights,California
Aug 26, 2008
#24
  • Aug 26, 2008
  • #24
Depending on your headersi had try-y's and mine out of 16 ports, i was able to get maybe 9-10 on, the rest wouldnt fit.
Blue67
31
Long Beach, Ca
Aug 26, 2008
#25
  • Aug 26, 2008
  • #25
I had the same problem with my header bolts on edelbrock performer heads. I needed longer header bolts. Look at the specification of how long the header bolts can be.
I run Thorley headers. I also use grade 8 bolts.
Good luck.
R
ron67fb
1,117
SF Bay area, CA
Aug 26, 2008
#26
  • Aug 26, 2008
  • #26
Same story on my shorties. I had to cut some of the tabs to clear the tubes. The nice thing about them is having the allen head in addition to hex, but I believe you can get that on some regular header bolt sets.
C
Cobra ssc
80
Austin, TX
Aug 26, 2008
#27
  • Aug 26, 2008
  • #27
ron67fb said:
I used the Stage 8 bolts before and the gasket I had blew out so that didn't help much.
Not to be an a$$, but it sounds like cheap gaskets or user error. Whether using Stage 8 or another type of header bolt will not make a difference in that situation. The main thing is to not have an exhaust leak and create a lean condition. I run mostly boosted applications on my Mustangs and a header gasket leak can easily turn into a blown head gasket, which is much worse.
I too had to modify my Stage 8 bolts to work, but isn't that part of using aftermarket high performance parts? Maybe I'm just used to having to make custom parts to work with my combinations. I have already purchased another set of Stage 8 for the 65 since I believe that they are cheaper than installing new head gaskets.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 26, 2008
#28
  • Aug 26, 2008
  • #28
Stage 8 = hype
Copper gaskets or standard with some RTV on both sides will help.
I can only imagine geting to those header bolts on your 65 with that 351w....
D
D.Hearne
11,730
south louisiana
Aug 26, 2008
#29
  • Aug 26, 2008
  • #29
Those are easy, try doing all 32 bolts on a 428CJ headed FE in a 67-70.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 27, 2008
#30
  • Aug 27, 2008
  • #30
32 little reasons to drink.....
SadbutTrue
2,391
Aug 27, 2008
#31
  • Aug 27, 2008
  • #31
Seriously man... there are a couple bolts that are going to leave me bloody, I'm sure.
That said, the thing hauls Once it warms up its a rocket, I have yet to find an opportunity to actually stay on it for more than a few seconds, let alone row through 2-3-4 at WOT.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 27, 2008
#32
  • Aug 27, 2008
  • #32
You want me to drop by on my way home Saturday ?
SadbutTrue
2,391
Aug 27, 2008
#33
  • Aug 27, 2008
  • #33
I'm gonna be in the bay area for football this weekend. Maybe next weekend if you're free and bored. I'll supply beer.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 27, 2008
#34
  • Aug 27, 2008
  • #34
Sounds good.
First Prev 2 of 2
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
