header leak question
  • Thread starter Thread starter fox-gt
  • Start date Start date Mar 6, 2006
fox-gt
204
TN
Mar 6, 2006
  • Mar 6, 2006
Two weeks after a full exhaust install and I believe I have a header leak. I have tightened all the bolts, but I hear a ticking sound by the header. After searching here for a while, most of the posts point to a leak. Others have mentioned the plugs, checked them they are fine. I had to take the header off the day after the install to shimmy the motor mount. This will be the third time I have removed this header
Two Questions:
Do I have to take it completely off to change the gasket? (It has only been on for about two weeks).
What gasket brand would you recommend? There are many to choose from on summit's website.
Rynb15
132
Mar 6, 2006
  • Mar 6, 2006
i had better luck with stock autozone gaskets. I believe i had felpro? gaskets and they leaked on both sides. The ticking drove me crazy. Then a mechanic told me to get stock ones and they were fine
J
jerryD
1,061
Gladstone, MO
Mar 6, 2006
  • Mar 6, 2006
also check the ball and socket connection as well. other wise if it is a gasket, i reccomend Mr. Gasket Ultra Seals.
JBeezy53
559
Sacramento, Ca
Mar 7, 2006
  • Mar 7, 2006
I 2nd the flange. I think I have a little leak there but I can't get it sealed. I thought I seen these gaskets for the ball and socket a long time ago but haven't had any luck finding them since.
fox-gt
204
TN
Mar 7, 2006
  • Mar 7, 2006
Something like this?
http://store.summitracing.com/partd...4294924761+4294923429+4294856299&autoview=sku
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Mar 7, 2006
  • Mar 7, 2006
I find that the best type of header gaskets are the graphite ones. Some don't like them, but I have had the best luck with them. As for the header collector, I use a bead of ultra grey RTV to seal that up as well as all the other exhaust connections on my car. No more exhaust leaks for me.
DeadLifter
183
Portland, IN
Mar 7, 2006
  • Mar 7, 2006
I also put a little bead of RTV around the port holes in the gasket. Check flange. Header could be warped?
fox-gt
204
TN
Mar 7, 2006
  • Mar 7, 2006
Two week old header could be warped, that would stink. It didn't make the noise the 1st week.
When I went to tighten up the header bolts last weekend they were still tight, maybe 1/2 turn to tight them all the way on three of them. The flange was a few full turns loose.
I will check the flange again on saturday. If I have to replace the header gasket, can I just undo all the bolts but the outer bolts, loosen them and replace the gasket or do I need to remove the whole header?
Sorry if I am beating this into the ground, its kind of a bummer. I saved for a long time to get all of this and it has been a nightmare for me. It would not be that bad if this was not my DD or I was more skilled at car repair.
MUSTANGJOE
Silver Stanger
1,644
17
59
Mar 7, 2006
  • Mar 7, 2006
I had that same problem!
I bought stage 8 locking bolts from 50resto.com and installed them with some new gaskets and it never happened again...make sure you buy those bolts or it will most probably happen again..good luck!
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Mar 7, 2006
#10
  • Mar 7, 2006
  • #10
Took the words right out of my mouth. Ive struggled with headers on all kinds of cars, locking bolts make all the difference in the world!
DeadLifter
183
Portland, IN
Mar 7, 2006
#11
  • Mar 7, 2006
  • #11
(If I have to replace the header gasket, can I just undo all the bolts but the outer bolts, loosen them and replace the gasket or do I need to remove the whole header?)
Been awhile but I think I've done it that way. Headers probably aren't warped, but it has happened. Try the RTV around the port holes in the gasket. (Small bead.)
RacEoHolic330
4,014
1,698
203
Allentown, PA
Mar 7, 2006
#12
  • Mar 7, 2006
  • #12
Personally, I think that locking bolts are just a band-aid for a deeper problem. The reason why bolts keep backing out is because the flanges on the headers are not flat and true. Most of the people that have problems with bolts backing out are using MAC headers. I had the same issue as well with my MAC headers and even bought locking bolts. I bought a set of Bassani headers and used standard bolts when I installed them. I heat cycled them once and they haven't leaked a bit since. As long as both the head surface and the headers are square, bolts should never back out.
fox-gt
204
TN
Mar 7, 2006
#13
  • Mar 7, 2006
  • #13
What size, ordering now.
Original bolts were 1", BBK ones are 3/4"
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M9432A50 1&comp=LRS
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M9432A51 1&comp=LRS
RacEoHolic330
4,014
1,698
203
Allentown, PA
Mar 7, 2006
#14
  • Mar 7, 2006
  • #14
get 1" bolts
fox-gt
204
TN
Mar 11, 2006
#15
  • Mar 11, 2006
  • #15
Got the gaskets changed today, the old ones crumbled when we pulled the headers off. The stage 8 bolts were awesome. Both sides were leaking bad. The ticking turned out not to be the exhaust but is something under the valve cover. (probably a rocker)
Thanks everyone for your help.
JDS95GT
427
Oct 27, 2006
#16
  • Oct 27, 2006
  • #16
One of Mac's main selling points is just what you mentioned. Mac don't use a full flange and should have less of the problem you mentioned. It took mine 6 years to start leaking with the paper gaskets and bolts Mac supplied. Due to the crappy HTS coating looking bad now, I am looking for a replacement. I may go with the ceramic coated Mac's.
Dave
7-UP BILL
885
My other car is a Firetruck
Oct 27, 2006
#17
  • Oct 27, 2006
  • #17
Had same problem, used ultra seals and stage-8's. Been 10 years without a problem
fox-gt
204
TN
Oct 27, 2006
#18
  • Oct 27, 2006
  • #18
It's ironic. The #6 ring broke a few months later and the engine had to be rebuilt.
The locking bolts are worth every penny.
P
postalbunny
118
Oct 27, 2006
#19
  • Oct 27, 2006
  • #19
I 2nd this, i bought the locking bolts when I did my install but havn't gotten around to installing the locking part of them... not leaking. I used copper mr gaskets though, cost more $ than graphite.
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
