Header Question
  • Thread starter Thread starter 65stangCT
  • Start date Start date Dec 19, 2005
65stangCT
11
  • Dec 19, 2005
I am installing a 331 stroker with 400HP, and a 2.5 magnaflow exhaust. I am looking to use Thorley Headers. The car is a 65 Coupe for street use.
My question is Long tube or Tri Y, and what are the plus/minuses of each.
Thanks
LMan
1,246
Mom's basement
Dec 20, 2005
  • Dec 20, 2005
Since Im guessing you have aftermarket heads, I recommend longtubes if you can make them fit with your steering.
T
The Dan
319
Orange County, CA
Dec 20, 2005
  • Dec 20, 2005
Though I don't know all the pro & cons, ask yourself this...how many pro-stock cars have you ever seen with Tri y's? Since those guys look for every competitive edge they can get I would say that there has to be some legit reason they choose long tubes over tri y's. However, I think Tri-y's are more suited for the street and develop there power down low, where as the long tubes will breath better up top. If your only going to run on the streets I would lean towards the tri-y's since you'll be spending most of your time in the lower power band going light to light. Though I do like the sound of my long tubes. Very throaty.
65stangCT
11
  • Dec 20, 2005
Thanks guys. I spoke with a representative from Doug Thorley and they reccommended the Tri Y. Basically the TriY gives better low/mid range torque, and the Long tube doesnt start to produce until after 5000rpm.
LMan
1,246
Mom's basement
Dec 21, 2005
  • Dec 21, 2005
Hmmm, I see that with a 289, but you are answering the torque question with the stroker.......I don't see the >5000-RPM argument at all. They must mean that LTs outshine Tri-Ys >5k, at least that is my guess.
...but I've been wrong before, I'm no header expert. But I would still select LTs over TriYs for a stroker.
rbohm
6,698
550
204
tucson,az
Dec 21, 2005
  • Dec 21, 2005
for the street, i say tri-y's as they make better mid range torque that the 4-1's(both are technically long tube headers). i would however recommend that you get tri-y's with a 1 5/8" primary tube, as the 1 1/2" tubes that shelby used are going to be a bit smalle for your motor. and yes, the 4-1's have a power advantage above 5k rpm, though it really isnt very big.
SoCalCruising
2,437
SoCal
Dec 21, 2005
  • Dec 21, 2005
You know, Doug Thorley doesn't own that comapny anymore. He now has Doug's Headers in Anaheim, CA. His current designs are superior to the old stuff sold at Thorley Headers. The old stuff is 1 5/8 primary, into 1 7/8 secondary, into 2 1/2 collector. The new stuff is 1 5/8, into 2" into 2 1/2, with better transitions. Fit is great - I have Doug's on my '66.
As for Tri-Y applications, they are the preferred header for many high-end NASCAR applications, given that they look a lot different than what we can get. The NASCAR primary tubes, especially, are longer and tuned for max. scavenging. The secondary tubes are also longer. As for street applications, I have seen several dyno runs where Tri-Ys give up a little down low, compared to long tubes, but have superior mid-range, and aften better high-end power. Fit is generally better on our cars and, since you will be having traction problems anyway, you should be happy to give up something down low (where you can't use it) for more mid-range (where you can use it).
Ummm, people often say that long tubes make better top end. The question is: compared to what? Compared to stock manifolds - YES. But, when just comparing tubular headers: long tubes are good through mid-range RPMs; Tri-Ys not quite as good at low RPMs, but better at mid-range RPMs; and shorties give up low and mid-range power for top end. That all assumes comparable tube sizes. Enlarge the tubes and we're not apples to apples anymore. Make sense?
Hope that helps.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
