Header questions...different than normal.
  • Thread starter Thread starter 5spd GT
  • Start date Start date Oct 27, 2005
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 27, 2005
  • Oct 27, 2005
I have some Equal Length Mac 1 5/8th's that have some age on them. They never have bolted up right to my AFR's. One side always seems to short. I believe they need to be "trued". Do machine shops do that? I don't think it seals up flat
Also I need the right exhaust gasket (FEL-1416?) that actually will fit over and still seal against the 1 5/8ths...because the FEL-1415's overlap the exhaust ports on the AFR 165's. I don't like that restriction...any thoughts?
What is a good way to clean out the inside of the headers?
Also I bottomed out my car and put a nice little dent (disrupts air flow) at the kink where the hpipe starts going up towards the header? What can I do? Special tool? It pushed it up probably a good 1.5 inches.
Thanks
Modular2v
3,222
23
99
oklahoma
Oct 27, 2005
  • Oct 27, 2005
ummmm buy new headers... probably cheaper and alot less hassle
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 27, 2005
  • Oct 27, 2005
Well having them trued would be probably $20 bucks and they flow fine. Cleaning is free with some elbow grease. The dent is in my h-pipe and I'm sure I can "remove" that for much less that the price of a new h-pipe.
Thanks for the response
Swarzkopf
973
Pittsburgh
Oct 27, 2005
  • Oct 27, 2005
5spd GT, they make an exhaust system tool designed to remove "dents" in exhaust pipes. Generally, this tool is used when someone over tightens a muffler clamp and pinches the pipe, but it should work for you as well.
If your local auto parts stores don't have it in stock, I believe that Summit sells it.
F
fiveohGT
353
Fairfax Virginia
Oct 27, 2005
  • Oct 27, 2005
To clean out the inside of your headers you can probably get away with soaking them in gasoline and running some kind of steal brush through them.
Modular2v
3,222
23
99
oklahoma
Oct 27, 2005
  • Oct 27, 2005
sorry i read wrong i thought u said the dent was in your headers
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 27, 2005
  • Oct 27, 2005
I'm thinking of going with longtubes now and changing somethings while I'm doing them...I don't know what I want to do
Thanks for the replies...suggestions are welcome
I
IntenseBlue
946
  • Oct 27, 2005
Get longtubes.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
