Headers for AFR 185's
Rick 91GT said:
The .027" gasket will not give you enough quench area, stay with a .039-.041". The 4.03 bore makes very little difference, as you can see below..
Compression Ratio Calculator v2.d
Thursday, March 09, 2006 2:45 pm
* 302 cid *
Bore Size: 4.030
Gasket Bore: 4.100
Piston Top Land Dia: 3.995
Stroke: 3.000
Connecting Rod Length 5.090
Compression Height: 1.600
Deck Height: 8.190
Ring to Top of Piston 0.250
Gasket Thickness: 0.040
Valve Notches Volume: 8.00
Dome Volume: 0.00
Volume Head: 58.00
:COMPRESSION RATIO: 9.299
What's a good compression ratio to shoot for? I can always mill the heads. I would like to be able to run 89 octane.
56cc will get you 9.5
54cc will get you 9.7
I really do not think you will see major gains by doing that and by milling them down smaller you limit what you can do in your future.
You should have no issue with your goals with a out of the box AFR185, I would upgrade springs and go with a custom cam, and go get some 11 sec time slips.
