Headers
  • Thread starter Thread starter Z06killinSBF
  • Start date Start date Aug 28, 2009
First Prev 2 of 2
Federico Garza
37
Oct 1, 2010
#21
  • Oct 1, 2010
  • #21
You can have them ceramic coated black...
Az Pete
711
18
49
Panama City, Fl.
Oct 1, 2010
#22
  • Oct 1, 2010
  • #22
Maybe I am missing something thru this older thread.... The OP asked about info for headers fitting with an AOD.....seems very little info given for an AOD fitment.
Thought I might learn something as my '66 289 has an AOD and Flowtech Terminators. They hang real low as the car sits down some too. Looking for something that will fit up closer to the floor or I might have to go to shorties. Real tired of dragging the ground plus the tubes being crushed are getting restricted.......
R
ralph6648
Elk Grove, CA
Oct 2, 2010
#23
  • Oct 2, 2010
  • #23
Update: Tried using the new repo-type cast 289 Hipo headers, but the exhaust ports on the passanger side did not line up with the exhaust ports of the AFR heads. Found the Patriot Tri-y ceramic headers fit nicely with a little modification to the bell housing and clutch Z-bar on 4 speed car. I had to trim the bell housing at the edge where the starter motor is mounted; needed about a 1/4" trimmed off so the header tube cleared the bell housing. To make things fit on the drivers side, for the transmission clutch linkage I had a Z-bar made by a local machine shop. The new one is similar to a hipo Z-bar, except the lower end where the lower clutch adjusting rod connects is made about a 1/2" shorter than a hi-po Z-bar so it clears the header tubes that run under the Z-bar (hopefully that makes sense). By the way, a big thanks to American Mustang in Sacramento for taking back the cast 289 hi-po headers that are improperly made, and giving me credit toward the Patriot Tri-ys. Another comment is, why don't the manufactures make parts that fit as they state? Must be that no one who works for the manufacture has the guts to tell their bosses that the parts they make really "don't fit", or the manufactures really don't give a damn as long as they can sell what they are already making!
N
npg3
31
#24
  • Oct 2, 2010
  • #24
I am buying the FPA headers from Stan....wealth of information and it looks like a great product. The price mark is between the cheap Reproduction and JBA. They work well with an AOD, power steering, and both types of starter casings. He has the 4-tube design for those who want to upgrade their Automatics but who do not want to drag or be seen low.
S-Car-Go
332
San Jose, CA
Oct 3, 2010
#25
  • Oct 3, 2010
  • #25
npg3- I love my FPA headers and I like any headers with "ball and socket" over a gasketed flange, BUT are you sure sure you can use these headers with a Arvinode exhaust? Arvinode is a 2" system and my FPA headers have 3" collectors (necked down to 2.5" exhaust system). Going from 3" collector to a 2" mid-pipe would be quite a stretch. Maybe you are ordering a different model, but I would ask about this.
First Prev 2 of 2
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 3 4 5
2K
Classic Mustang Specific Tech Friday at 12:39 PM
horse sence
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
