Well, I took apart the headlight switch and fog light switch to fix the common problem on our stangs of our headlights going out because of the line burning out or backing out of the socket.
I found the switch burnt so I ordered a new one, great, hooked up, still didnt work, so I followed the red/yellow wire to the Multi Function Switch (aka the signals and flash to pass stick) and I took out the red/yellow switch there to find another burnt connector (pics below) This sucks!
Where can I buy this 4 pin connector?
Also, the red/yellow wire that came with the switch was thicker then the one Ford uses (pic below) the new one looks to be 12 guage as the old one is 14 guage, is it ok to connect 12 guage to 14 guage wire or am I looking at more problems by doing this?
The damn red/yellow wire burnt on both sides of the connector, one on the headlight side, and one on the multifunction switch side! So I was going to replace both connectors but still use the ford oem wire, so it would be 12 guage wire, into 14, back into 12...
Where can I buy this 4 pin connector?Also, the red/yellow wire that came with the switch was thicker then the one Ford uses (pic below) the new one looks to be 12 guage as the old one is 14 guage, is it ok to connect 12 guage to 14 guage wire or am I looking at more problems by doing this?
, just run a 12-gauge wire from the headlight switch, along the harness, to the column. BTW, my connector was damaged by the small brown wire, the INTERIOR ILLUMINATION of all things.
While you're in the connector-replacing mood, why not check out the A/C heater fan speed selector switch plug (whew that's a big phrase). They go bad easy too. And of course check your ignition switch & plug. If you don't have the revised Ford ignition switch (the one that doesn't catch fire) you should get that too. I have a '90 coupe, but my ignition switch has a '92 part number, so it was replaced sometime.
