hey my stock headligts on my 1970 are dim as
. theres a couple options on cj pony but idk if theyr any good.... any suggestions?
. theres a couple options on cj pony but idk if theyr any good.... any suggestions?hey my stock headligts on my 1970 are dim as ****. theres a couple options on cj pony but idk if theyr any good.... any suggestions?
My biggest concern about any of the kits is that they don't specify wire size, which is why I made my own. Even though I got relays that had pre-wired relay sockets, the wires were #18 at best (even the supply), so I put new terminals and wires into them. They should be absolute minimum #16 to the lights and #12 for supply from the battery. I went with #14 to the lights and #10 for supply.kylehamilton,
You are lucky that you have not burned up any wiring or your headlight switch yet!My biggest concern about any of the kits is that they don't specify wire size, which is why I made my own. Even though I got relays that had pre-wired relay sockets, the wires were #18 at best (even the supply), so I put new terminals and wires into them. They should be absolute minimum #16 to the lights and #12 for supply from the battery. I went with #14 to the lights and #10 for supply.
http://www.summitracing.com/parts/PCO-5591PT/
HTH,
Gene
