heads and cam
  • Thread starter Thread starter usaf1313
  • Start date Start date Nov 30, 2009
U
usaf1313
memphis
Nov 30, 2009
  • Nov 30, 2009
im looking at putting some gt40 heads on my car(cant afford any aluminum heads) and a cam. my question is what would be a good cam to put in with the most lope? i looked into the thumpr series but ive been told not to. so any input would be great. gt40 is about the only set of heads i could get for 500 correct?
strtrcr50
Previously from Dirty Jerzey exit 7a
Nov 30, 2009
  • Nov 30, 2009
Is your main goal out of a cam its lope? You could always have your pistons notched and run an x cam. That'll lope pretty good.
YouTube - 1993 Mustang LX LE - X Cam Idle
If you don't want to notch the pistons, a B cam might get you the sound you are looking for and it SHOULD clear. Measure to make sure though.
YouTube - A mustang w/B303
strtrcr50
Nov 30, 2009
  • Nov 30, 2009
As far as the heads go, you can try to get a set of used gt40's as cheap as possible because you should get them checked out by a machine shop. Another alternative would be ProComp or Patriot Performance. They aren't the greatest heads, but they are better than a gt40 and iirc, you can pick up either one for under $800.
For cam selection, you could also call Comp tech lines and tell them what you have and what you are trying to accomplish. If you just waant to get an idea, comp has posted it's cam quest software for free.
CamQuest 6 -FREE Download from COMP Cams
stykthyn
5,232
2,652
223
gainesville
Nov 30, 2009
  • Nov 30, 2009
keep the stocker and unplug a vacuum line. lopes like crazy. will have the same effect on power as throwing in an alphabet cam too.
seriously aside from gt40 heads what is the rest of your combo looking like? there are more variables here that need to be addressed before anyone can offer any cam suggestions....
strtrcr50
Nov 30, 2009
  • Nov 30, 2009
Personally, I'd recommend you call Rick at RNH Performance. He is a sponsor here and will give you good advice on your combo.
RNH Performance -Street and Race Engines, Custom Fabrication
Shaun1212
22
toronto, canada
Dec 1, 2009
  • Dec 1, 2009
Cam
If your going to notch the pistons, go for the Z303 cam
M
mikepotts
81
  • Dec 1, 2009
x's 2... maximum lope!
j/k, btw... ive never had problems clearing an X cam with stock heads and pistons (uncut). just dont use 1.7 rockers with it! you can use either a B or E with 1.7's with no trouble.
M
mikepotts
81
  • Dec 1, 2009
IIRC the B cam combined with 1.7's ends up being real close specs at the valve to the X cam.
U
usaf1313
memphis
Dec 1, 2009
  • Dec 1, 2009
well i bought the car about 2 weeks ago. i was told it was a 308. from what i can tell by looking at it, it has stock heads, shortys. so im guessing i need to take it apart to see what alls done? i talked to a guy i work with about getting some gt40s with roller rockers already mounted for about 300 bucks not sure about the specs. from driving my car it seems to be an extremely strong 5.0. it could be the retardedly loud exhaust and the 4.11 gears throwing me off.
U
usaf1313
memphis
Dec 1, 2009
#10
  • Dec 1, 2009
  • #10
also. what all is involved with notching the pistons? what is an average price i would pay for this?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 1, 2009
#11
  • Dec 1, 2009
  • #11
Posted via Mobile Device
Price would depend on the shop, but around my way its $75 to notch all 8 pistons.
Or.....You can do as I did and notch them yourself. All it cost me was 2 used 2.02 and 1.60 valves, some 80 grit belt sandpaper, and about an hour of my time.
Ill try and post some pictures of the process later on.
skunk21
1,203
Taxachusetts
Dec 1, 2009
#12
  • Dec 1, 2009
  • #12
Anderson motorsports N-41 cam. great cam for the GT40 heads, works with 1.6rr's and has a nice lopey idle. nice customer service to boot, they will set you up.
U
usaf1313
memphis
Dec 2, 2009
#13
  • Dec 2, 2009
  • #13
well i been looking around and people say notching yourself isnt too bad.i found some gt40s worked over with 1.7 roller rockers for 3, i can prob talk him down from that. anybody know anything about the thumpr series? the one i want says i need 9.5 to 1 compression, do i have this? will the gt40s give me this? i know its alot of questions, but you guys have already built these motors and i have not. also will gt40s fit on a 351w? i can get a windsor for free.
stykthyn
5,232
2,652
223
gainesville
Dec 2, 2009
#14
  • Dec 2, 2009
  • #14
yes, they will fit on a 351. you'll be choking the snot out of it, but they will bolt up.
Shaun1212
22
toronto, canada
Dec 2, 2009
#15
  • Dec 2, 2009
  • #15
To Mikepotts
I suggested the flycutting to be safe. I had the X and still flycut. 542 lift... isn't that cutting it kinda close? what do you mean by j/k btw?
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
