heads and compression ratio formula?
I wanted to know if anyone knows the formula to figure out what compression ratio you will get, i.e Say i buy flat top pistons that have a 10:1 CR with a 64cc comb. chamber, and i buy heads with a 60cc comb. chamber......how can i figure out how much higher the CR will be?? ANd one more thing, im considering getting some AFR 205's for my 351W. I see that it is advertised with "mechanical" valve springs, and the 165 and 185s are advertised with Hydraulic. My question is, if i go with the 205's does that mean i have to run a Mechanical Roller cam instead of hydraulic roller b/c the heads valve springs are mechanical?? Hmmm...:shrug:
To do it you need to know the following:
CR = Compression Ratio
Sv = Swept Volume (1/8 Engine Displacement)
Cv = Crevice Volume (all the other places that air and fuel can be: head gasket, between the piston and cyl walls above the top ring, valve relief’s)
Cc = Combustion Chamber
CR = (Cc + Cv + Sv)/(Cc + Cv)
If you know everything but your Cv, you can figure it out to be around 15.887cc. Then you can figure out what your CR is for your 60cc heads:
CR = 10.47 (if my math is correct)
hey thanx guys....guess ill have to do some measuring! haha! yea im not sure whats up with the valve springs either, does anyone know the difference between the hydraulic and mechanical valve springs?
Give me what information you have, with the above formula, and I'll do my best to fill in the rest.
Do you have a part number for the piston you are looking at?
I imagine the mechanical valve springs is for mechanical tappet cams, usually given to higher rpm capable camshafts. You will need to swap them out for some hydraulic camshaft compatible valve springs:nice:
Call the vendor and find out if you can get the head with springs for your setup. Also, if you are by chance looking at KB's for pistons, you can punch in head size with the piston you want and it will compute the CR for you. I'm going to be running 10.2:1 with 60cc chambers and KB9925's
This is really a simple calculation.
You have basicly two volumes to consider, that with the piston at the bottom (big volume), and that with the piston at the top (small volume). Compression ratio is just the big volume divided by the small volume.
Big volume is the space above the piston in the cylinder plus the head chamber volume.
Small volume is the head volume plus the deck clearance.
There is some aggravation in rounding up all the pieces that make up the small volume, ie, chamber, valve reliefs, deck clearance, annular volume above the top ring etc, etc. Some of it you can probably neglect for practical purposes.
Its easiest to do a spreadsheet, to make it easy to look at the effect of different chamber volumes, heads, etc.
Ok, i think i have a good idea now on how to figure it out. Lemme ask one more question here concerning the heads with mechanical valve springs. My buddy at work has a 10.50s N/A 347S notchback. He has the AFR 205 heads and he has 10.9:1 CR. I asked him about the springs and he said he just converted his motor to Mechanical Roller instead of hydraulic roller, which most of us know can handle more RPM than hydraulic. My question is, since im planning on ordering the whole valvetrain soon (including the retro-fit hydraulic roller lifter kit to make my '75 351W block a roller) should i just step it up to a mechanical roller setup instead? From what i understand, the reason that you have to get retro-fit lifters to run a standard roller cam is b/c the lifter bores are to short in a flat tappet block, and the roller blocks have longer bores?? right? The guy at work said that the Mechanical roller lifters are shorter than the hydraulic roller......soooo.....could i just run a mechanical roller setup?? I think i may go out of my mind soon!:rlaugh: Just so many dam options! Can i even do this with my block, or just stick to the hydraulic roller conversion???
I personally would go with a hydraulic set-up. There may be some truth to the old tappet lifters being shorter, which I think is right, but I do not know about the lifter bore length difference.
However, the block needs to be have threads machined into the lifter valley so one can bolt-up a spider hold down bracket. It is two bolts.
The spider hold down bracket has little arms that keep these "X" shaped bars in place. The "X" shaped bars keep the roller lifters from rotating in their bores.
Hydraulic roller set-ups are usually more stable and predictable, and you can make them work with AFR 205's for sure.
I think going to mechanical route is just a way to save money. But if you are on a budget, by all means, that is okay.
Maybe someone will help you out in the conversion process:)
