Heads / cam swap DONE, a few pics and info here
HAhaha
I'm 6.6" 300lbs :D
Smoke comme from oil/water on the headers just burning off,
Today I play little bit with idle ,it's too hard to adjust, when I start the engine I have play little bit with gas pedal about 30 seconds and after that idle come on 900rpms and stay there , IF I just leave gas pedal after starting engine ,Stang will stall after 10 seconds because idle goes up and down :rolleyes:
I know I need tuned ,and get meybe PMS, tweecer or ....? but for now is good
One more thing , when engine get how, I mean work temp. it pinging , I use 93 octane gas, anybody have same problem, I clean new MASS and IAT but still nothing
Slow5.0 said:
HAhaha
I'm 6.6" 300lbs :D
the pinging is probably timing, or running lean....id check both
Killercanary said:
I've never seen a car NOT smoke like that after a H/C/I swap. Usually it is from the antiseize and such used on header bolts, etc.
Lol...that would freak me out if it started doing that...but now that i know...I'll expect it...I'm almost done with my FTI combo (hopefully get it started tomorrow or the next day)...
Do I set my balancer at 0* or 10* or what when I go to install the distributor?
Tonight I was playin little bit on HWY and car is faster about one full second than before without tune
ABout pinging , I have fuell pressure at 36psi or 44 without vaccum hose, I bump to 40psi or 48 w/out vaccum hose, looks like is pinging little bit less
Timing is 13.5 , I don't have any CEL but I do check anyway with paper clips and I got with "key on ,engine not runing" code fro battery to PCM fuel pump circuit open" thats erorr because I have this code allways, nothing wrong,than I start engine and try "key on ,engine runing" and I got CEL#133 left O2s real lean , so meybe its lean DAMN fox body PRO-M 75mm MASS calibrate for 24#, meybe I need 80mm and exact for 94-95s
