Engine Heads Up!
joetrainer31
869
364
114
SC
Ok brainiacs, I could use some help planning out my future mods. I'm debating between two different heads for my car. I will be keeping the stock GT cam w/cobra 1.7 RRs and retarding it 4 degrees regardless of head selection. Below I'll tell you what I have on the car. Given my mods and cam selection would you all please drop some knowledge on me as to which head and why?
- 95 GT vert (54lbs weight already removed, most up front)
- 5 spd
- stock block
- SVO GT40 intake (will have lower ported for new heads)
- 65mm FMS TB
- FMS shorty headers
- Flow Master cat-back
- factory h-pipe (CA smog)
- 70mm factory MAF
- 373 rear gears
- will upgrade to 24lbs injector
- will upgrade to larger fuel pump
- will have tune for new set up.
After tossing my iron GT 40s, my 2 choices are TFS TW or AFR 165s. Which head set and why given my combo and stock cam w/1.7RRs?
I've done the 4 degrees retard on the cam. You would think 4 degrees is nothing boy was I wrong. The powerband was horrible. It wanted to make power from 4500-6800 rpm and I wasn't comfortable with that. I also wasn't comfortable with revving the hell out of it in regular driving conditions. It was the only want to get it moving. After a few weeks I installed the cam straight up and was so happy afterwards.
Thanks, man. That's good to know. What do you think about a 2 degree retard to take a little better advantage of the head's breathing capacity? This will be a daily driver/weekend cruiser.
Mine was just a show car really and maybe 500 miles per year. I don't know what cam you're going with but I've been down this road and I don't recommend it. Nothing like doing this twice in a few weeks time, that's how disappointed I was. Not with the power it made, just were the power was made. I broke a Steeda high rev valve spring at 6300 RPM, hi-rev my arse.
Okay, this is good info. I'm going to ask you to clarify not because I'm looking for someone to eventually agree w/me, but because I want to learn/understand what you are saying.
1) So, even at a 2 degree retard on the stock cam you say "no?"
2) If I'm looking for a boost in performance w/o the added expense what about re-installing the stock cam straight up?
3) Correct me if I'm wrong: Installing a set of 165s instead of my GT40 irons, even w/the stock cam, will give a noticeable increase in power.
