Heads
  • Thread starter Thread starter Justin422
  • Start date Start date Dec 27, 2015
Justin422
29
  • Dec 27, 2015
I just found out the bill to have my heads taken to the shop is probably going to be over $300. Wouldn't it be smarter to invest into new heads? I would like to get a set of less expensive heads and drop some good hardware into them. Does anyone have any suggestions (w/links would appreciated).
Are these okay?
Cylinder Head N351 M-6049-N351 - FordRacingPartsByDonWood.com
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Dec 27, 2015
  • Dec 27, 2015
That's for 1nhead, no parts. You will need valves, with a valve job, springs, seals, spring cups, locks, retainers, studs, push rod guides and assembly cost. You will be well north of $1k and might as well buy a set of nicer aluminum heads already assembled.
What does the $300 get you on your current heads?
Joe
Reactions: Justin422
stykthyn
5,232
2,652
223
gainesville
Dec 27, 2015
  • Dec 27, 2015
To truly answer this we need to on know what heads you have. E7 heads are door stops. I wouldn't put any money in then whatsoever. Gt40 heads are slightly better and at 300 dollars may be worth fixing.
Justin422
29
  • Dec 27, 2015
I have e7. I want to get decent heads and great hardware to stuff em with.
Sent from my SM-N920V using Tapatalk
Justin422
29
  • Dec 27, 2015
Cleaned and milled I believe. Not sure if it includes porting.
stykthyn
5,232
2,652
223
gainesville
Dec 27, 2015
  • Dec 27, 2015
Take that 300, save another 500 and get some aluminum heads. Aside from paint, heads will be the single most expensive part of most car builds. Get the biggest you can afford. Back when we could find running explorers in the jy gt40 heads were a good buy, but those are getting harder to come by and aluminum heads have gotten much cheaper. You can get a decent set of used ones for under a grand. Well worth the money.
L
Lscam580
119
18
28
Grand Rapids Mi
Dec 27, 2015
  • Dec 27, 2015
Your able to pick up a set of 185cc Afr heads for $1600 they stuff them with the best parts you can buy. And some of the best results out of any head.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 27, 2015
  • Dec 27, 2015
Either go low budget for $500 and get a set of GT40 heads , good springs, etc. or spend $1100 and get a set of TFS heads.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Dec 27, 2015
  • Dec 27, 2015
What are your build plans? And how much money do you have budgeted? Like others have stated buy some aluminum heads. If you have the budget grab some trick flow 11r 190cc heads. They have great hardware and the design offers the most ptv clearances for an aggressive cam.
Justin422
29
#10
  • Dec 28, 2015
  • #10
I am building the motor now. I have a pro comp x303 cam I just put in. I want to do a fuel injection set up to turbo, something strong don't really want to bore or stroke. I have roughly $1000 to spend on heads.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Dec 28, 2015
#11
  • Dec 28, 2015
  • #11
Tfs 170cc heads would be a great buy for you. They run 11-1200$ new and plenty available used for around 750$. You can even port them out later so they can grow with you if you ever need bigger heads. Best option around for your budget.
Reactions: Justin422 and stykthyn
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Dec 31, 2015
#12
  • Dec 31, 2015
  • #12
You guys are going to kill me for doing this haha.
I just rebuilt my engine and slapped a pair of these on it. They were a huge significant increase in power along with a new lower and upper intake to match. I did not have the intake port matched yet either. That will be future. These are comparable to Ford Racing GT-40X heads. They were modeled off of them and enhanced by the machinist who developed them. I live down the road from the guy who own this machine shop and built them. I had long conversation with the guy. Especially when I found out they are china aluminum.
A lot of 30 something fords are using them on their hot rods. But they were built for the 302 ford small block. You will need a new intake to match these plus other hardware. They come with a complete valve job and springs ready to go but you will need roller rockers( I used 1.6), new hardened push rods, and taller valve covers(which means a lower intake spacer as well to clear the valve covers.
Speedway motors sells them:
Flo-Tek 203505 Small Block Ford Aluminum Cylinder Head - Free Shipping @ Speedway Motors
Or you can get them directly from the Indiana machine shop. Here is that site with specs.
Entry level performance - not CNC ported - 180cc Small Block Ford 180cc - Flo-Tek
CNC ported - 190cc - Small Block Ford 190cc - Flo-Tek
Now if your looking for big performance gains, you should just save your money and go with the AFR or Trick Flow heads, but I was on a small budget and and VERY fast timeline to get my car back together at the time. Couldn't wait for more money.
Anyway, I haven't dyno'd the car yet but I can tell I have significant gains. I was told I should see at least 50 more horse from the heads from stock. At least he said. Then more with the intake you choose. It's a massive difference, not going to lie. I'm also using a supercharger too so it works well with it too, but I had that before the rebuild.
I'm street performance only. No track. Been a year since rebuild and she is running good. I don't intend to see any issues down the road either. I ended up talking to a couple guys that have them installed for many years on their old 30's hotrods with 289's and 302's in them.
That's if your on a budget bro. AFR and TrickFlow are a better design and you will get better flow from them but this is another option if it fits your application.
PS: You can have these suckers modified with different springs and valves or whatever when you buy them, just call the boys at the indiana machine shop(tri state cylinder head) and they will hook you up.
And for you other guys. Don't be too harsh on me
And I hope I don't get kicked out of the club for this either lol.... I like you guys...
stykthyn
5,232
2,652
223
gainesville
Dec 31, 2015
#13
  • Dec 31, 2015
  • #13
Ok, here's the thing with Chinese heads. They are crap. Sure they are cheap, but by the time you are done buying everything you need to put them on, or finish cleaning the castings you are right in the ball park of a good set of afr or tfs heads. Patriot, pro-comp, flo-tek, we've all seen and documented builds with them on this board. Sure you will see gains, but the fit/finish quality usually isn't there.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 31, 2015
#14
  • Dec 31, 2015
  • #14
Come back in a few thousand miles and tell us how those heads are holding up
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Dec 31, 2015
#15
  • Dec 31, 2015
  • #15
Lol, I knew that was coming. I will keep you guys updated in my thread on how they are doing from time to time.
And @stykthyn is right, you can get better heads, but I didn't do anything to these, just upgraded the springs and bolted them right on. Again, depends on what your trying to accomplish here. And I know chinese castings have a bad rep, but they are getting better, and how many things are made now in china? Machine heavy duty stuff. I just had to try them out for myself. It's what I believe. And I have not seen any builds on here yet(and I searched for weeks with different terms with no luck) using these flootek heads.
And then there is that fueling the chinese economy thing. But hey, were working towards a GLOBAL economy right? I dunno.
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Dec 31, 2015
#16
  • Dec 31, 2015
  • #16
Oh yeah, and those other 2 hot rod guys I talked to have been using these heads for over 10 years now. I don't know how heavy they pound on them though. 32 ford and 38 ford.
And happy new years you haters! lol
Reactions: OneWheelPeel
Need some advice on upgrading GT-40-X303 heads
  • 93gtmustang
  • Sep 1, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2024
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
