Heater core nightmare
  • Thread starter Thread starter chobracobra
  • Start date Start date Oct 27, 2004
chobracobra
175
jersey shore
Oct 27, 2004
  • Oct 27, 2004
I have to replace the dreaded heater core and ordered the official shop manual for my 89 stang, and was wondering if anyone performed this job before. I've memorized the hilarous Chilton procedures and laughed at step 4 (remove evaporator case assembly) haha they make it sound so easy. The car is a daily driver so i need an estimate from anyone who did it, how long it will take. I am pretty experienced with my car so usually i can figure things out that will cause problems. and also; does the whole dash really need to come out or is there a way to "drop" it? thanks everyone
DTT92LX
185
Downingtown, PA
Oct 27, 2004
  • Oct 27, 2004
I think I saw a thread on here a couple weeks ago talking about not having to take it "all" apart. Something about cutting through the plastic housing and just dropping out the core.
I would do some searching, it didn't sound so bad the way it was described...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 27, 2004
  • Oct 27, 2004
See http://home.netcom.com/~skent/mustang/1990/heater_core/hcore.html
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Oct 27, 2004
  • Oct 27, 2004
i did mine without any book or anyone helping me in 7 hours. granted i did look at some stuff on here first
7upstang
75
Calgary, Alberta
Oct 27, 2004
  • Oct 27, 2004
Mustang monthly had a really good tech article on doing it. I used it when I did mine. It was way better than the Haynes manual. It took me about 5 hours. It's a PITA but the money you save makes it worth it.
Her is the link to the article
http://www.mustangmonthly.com/howto/5652/
Good luck
V
v8only
2,378
22
49
Oct 27, 2004
  • Oct 27, 2004
Don't cut the box, that's tacky. just ubolt the dash, very easy, and swing it down. I had mine completely removed for a dash swap. This will apply for all mustangs with a/c
TOOLS and supplies NEEDED:
-7/16 socket, preferably long socket, short extension and ratchet
-7/16 wrench
-5/16 short wrench
-5/16 socket and ratchet, preferably long
-Black RTV
-phillips screwdriver for door sill and kick panel removal
-3 to 3 1/2 inch socket to jam between dash and firewall for clearance
-Beer
1. Remove dash
2. A. Remove the nuts on the firewall on either side of the air conditiong accumulator. For this I used a 7/16 deep socket and short extension on both sides. Pull the bracket back on each side. Don’t be afraid to pry and bend the bracket back and away from the firewall, it won’t break, and it’ll bend right back on.
B. Now remove the nuts that were behind the bracket. I used the same 7/16 setup from before on the right side, and a 7/16 wrench on the one closest to the passenger side.
C. While you are there, take off the heater hoses going into the firewall and spray the heater core outlets with a white lithium grease so they will be lubricated enough to slip off the rubber grommet.
3. Pull the carpet back slightly on the passenger side. This is important for several reasons. The first is that coolant may spill on your carpet. The second is to gain access to the bottom housing nut seen in the following picture.
4. using a 7/16th socket, remove the very bottom housing bolt shown in the above picture and the top two housing bolts shown in the following picture.
5. Grab on the entire box and pulling it towards you, wiggle it out a few inches. When it’s out far enough the heater core outlets and studs will be on the inside of the firewall as shown in the following picture. Do not attempt to pull the whole unit out, it will not come out all the way with the air condition condenser still installed. The goal is to just pull it out just far enough to gain access to access the bolts on the top of the heater core lid.
6. Jam a socket between 3 and 4 inches long between the top of the heater core lid and the top of the firewall as shown in the picture. This is essential or you will not have any room to access the back bolts.
7. using a 5/16th deep or 8mm (it is possible to use a short socket but it’s more difficult) undo the front two heater core lid bolts. Now use a very short 5/16th wrench to undo the driver side rear bolt. Now use the deep 5/16th with the small ratchet to undo the passenger side rear bolt. Please keep in mind that these two rear bolts are a pain in the butt to remove, take your time and do not drop the bolts behind the back of the heater core box. Additional tip is that if you do not have enough room to pull the rear two bolts off, you can remove that plastic insulation that goes along the top of the firewall/frame.
front two bolts
rear passenger side bolt
8. Remove the heater core see picture. Be careful not to spill coolant.
9. Remove all of the old black silicone from the inside of the heater core box. Make sure all of it has been removed, this is critical
10. Put a bead of silicon(I used the black rtv) around the edge of the inside of the heater core box where the new heater core will rest, as show in the following picture. Lubricate the new heater cores outlets.
11. Slide the core in while a friend makes sure that the outlets slip through the rubber grommets at the firewall. The rubber grommet does not go through the firewall, it stays on the inside.
12. The heater core is now seated properly as you can see in the next picture. Bolt the lide back onto the heater core box. The passenger side rear bolt is not essential if you are having trouble putting it back on.
13. Pull the socket that’s jammed in there out. Push the box through the firewall with a friends help from the other side to watch. DO NOT TUG ON THE HEATER CORE OUTLETS.
14. Put the three nuts back onto the housing and put the nuts back onto the studs coming through the firewall. Bend your brackets back, put your final two nuts on.
15. Reinstall dash.
jaidedeye
627
Goldsboro nc
Oct 27, 2004
  • Oct 27, 2004
installing th heater core isnt that hard....iys the dash thats a whore......i did a complete dash swap while i was at it as well. while the dash is out you might as well tidy up the wires behind the dash and do some cleaning and tightening of stuff. also try to fix little squeeks and rattles in your dash if you had any.....
stangman8825
89
indiana
Oct 27, 2004
  • Oct 27, 2004
I think I'll wait until spring to tackle mine
F
FASTANG97
241
Jersey Shore
Oct 27, 2004
  • Oct 27, 2004
thats the exact write up i followed when i did mine two days ago....go for it!
84blkstang
544
Springfield MO
Oct 27, 2004
#10
  • Oct 27, 2004
  • #10
not to steal the thread but i think i need a new blower motor so anyone have a write up on that?
chobracobra
175
jersey shore
Oct 28, 2004
#11
  • Oct 28, 2004
  • #11
thanks a lot everyone, my confidence is a little higher for this job and i will start it very soon; its getting pretty dam cold here. "v8only" thanks for the great pics they helped put things in perspective.
R
Rock777
195
Troy, IL
Oct 28, 2004
#12
  • Oct 28, 2004
  • #12
V8only, that is an excellent write-up. I will be changing my heater core soon (or later), and will definitely use this advice. Thanks
M
Majsux86
Chicago
Nov 11, 2004
#13
  • Nov 11, 2004
  • #13
Does anyone have an opinion on what a good brand of heater core is for Fox bodies? I too am in the market for a new heater core and I don't want to do this job again and again because I got a cheep part. Now I'm figuring that the Ford factory heater core is the best but I found out that they don't make it anymore, not surprised, but I can get on for like $90. A bit steep for me right now.
So any advice?
J
JamesB88
228
North Kansas City
Nov 11, 2004
#14
  • Nov 11, 2004
  • #14
Do you guys have any pics of the heater core, Mine was disconnected when i bought the car so i fiqure it is bad. I heard that lots of 80s fords share the same one, I have one out of a 82 Granada, Fairmonts, and a few out of a cougar, according to a ebay auction the Grandad one would fit. But i would like a pic of one to see if it will before i yank mine apart.. Thanks James
M
Majsux86
Chicago
Nov 11, 2004
#15
  • Nov 11, 2004
  • #15
jamesB88, as far as I know Ford used the same heater core for all their Mustangs, Capri's, and Cougars up until 1993. I'll have a pic of mine up if you want (I know its bad) but it doesn't make a difference, you'll know if its bad by looking at it or better yet by filling it up with water. If its bad, it leakes. Simple as that man.
See the problem with many heater core's is first, poor installation. Next is bad luck. Finally its poor quality. That's why I'm looking for a better than average heater core for my GoD DAMN STANG!
Sorry,
Art
PNY PWR
522
Wichita, KS
Nov 12, 2004
#16
  • Nov 12, 2004
  • #16
50resto's got what they call a HD replacement
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=1055
J
JamesB88
228
North Kansas City
Nov 12, 2004
#17
  • Nov 12, 2004
  • #17
Well the 4 ford heater cores i found in my garage all are good. Filled them up with water, not leaks. They all just have differnt spots where the hoses go out at. Im not even sure the one in my car is bad. Id think it is since its didsconnected. I quess i could put some trash bags in my floor board and put some water in the one in my car and see what happens.. James
Also how can you have a Heavy duty heater core?? lol
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
D
Paint and Body Passenger side leak on carpet
  • dqureshi06
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
limp
