Heater Core Replacement Question
  • Thread starter Thread starter Lynx331
  • Start date Start date Aug 28, 2004
L
Lynx331
308
Chicago IL
Aug 28, 2004
  • Aug 28, 2004
I have a 87 mustang that i am replacing the heater core on. I have the whole dash apart. But does anyone know how the heater assembly comes off the fire wall so i can get the cap off for the heater core?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2004
  • Aug 28, 2004
see http://home.netcom.com/~skent/mustang/1990/heater_core/hcore.html for some help.
The Shape
2,224
East ARKANSAS Delta
Aug 28, 2004
  • Aug 28, 2004
If you are talking about the plastic box that holds the heater core and the evaporator core. There are two studs on it that go through the firewall. You have to remove the nuts off of them from under the hood.
L
Lynx331
308
Chicago IL
Aug 28, 2004
  • Aug 28, 2004
i have the nuts removed,and i followed that websites instructions and removed the bracket and i still cant get it to move out at all
Blakthorn
299
US
Aug 29, 2004
  • Aug 29, 2004
try this - http://www.mustangmonthly.com/howto/5652/
ALMOST STOCK
1,250
41
88
CA.
Aug 29, 2004
  • Aug 29, 2004
If you're still having problems this may be of some help also?
http://50stangs.com/techarticles/heatercore.html
W
wild50gt
51
nj
Aug 29, 2004
  • Aug 29, 2004
If you're positive you have all the bolts/nuts out, spray a little powerlube or wd40 on the rubber firewall grommet, and lightly tap the 2 firewall bolts and old core ends with a hammer. you will be surprised how tight that little rubber peice will hold that core in there.
jaidedeye
627
Goldsboro nc
Aug 29, 2004
  • Aug 29, 2004
I JUST DID MY HEATER CORE IN MY 90 LX
there are 2 studs that go through the fore wall and there are two bolts that hold the assembly on the inside.....did you pull your whole dash out? it makes it easier to get to everything. those 4 small bolts that hold the heater core cover on are a pain in the a$$ too if the dash isnt taken out completely
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Install 79-93 Mustang Heater Core Replacement
  • AeroCoupe
  • Oct 13, 2025
  • Resource Discussion Forum
Resource Discussion Forum Oct 17, 2025
85GTStangGuy
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
