Hey guys, I just got my heater core replacement, the old one was leaking. I'm ready to start, the manual doesn't say to drain anything but I think I should, anyone have any manuals or know a website that has it all?
You should drain your coolant. THis is prevent SOME mess
Ok, I finally pulled it out all the way, I had a small tube and I added a screw and a washer the size of the tube and I used a clamp to close it, it leaks a little but not as fast.
Anyway, So I opened up the unit, too out the core, scraped off all the dirt, and gunk, took off the blower, replaced the blower seals, and I stopped there. Then as I was assembling and cleaning I realized that I can't put in the other seals.
What sealant do I use to keep them on? Silicone sealant? crazy glue, etc...?
Also would I be able to drive on the a lower amount of radiator fluid and water? I just need to get it to the paint shop a mile away. when there he will probably repaint the engine, requiring to take off the hoses anyway and eventually replacing the coolant anyway.
Coolant in a motor is NOT like smoke in an electrical part. If you remove the coolant you can always put it back in the motor, but if you let the magic smoke out of the electrical part it will never work again and you can't just put new smoke back in.
