Heater Hose Tubes
  • Thread starter Thread starter palerider94
  • Start date Start date May 8, 2006
P
palerider94
573
  • May 8, 2006
There is a metal tube running accross the top of my manifold used to connect heater hoses. I've got a 302 1970. Tube is pretty much shot. All I can find is a tube for a 351C that looks like it but at $54 buck thru NPD seems a little steep. I could replace it and run hose. Just don't like the idea of a hose sitting on top of my manifold. Any ideas would be appreciated - thanks
M
mustangman1974
463
  • May 8, 2006
hmmm you talking about the fitting near the thermostat housing? If so I paid like 5 bucks for mine at larry's thunderbird.
bnickel
5,640
lubbock, texas
May 9, 2006
  • May 9, 2006
yeah they are kind of hard to come by. you can actually make one out of 5/8" od steel tubing, you could even use aluminum or copper if you wanted. just save the little hold down clamp from your old one so you can bolt it back down correctly. just make sure to to put a flare or something at the end so the hose doesn't slip off
P
palerider94
573
  • May 10, 2006
Thanks - looks like that is what I'll need to do. The old tab is spot welded - probably could fab something though. thanks
66HertzClone
428
Central New Jersey
May 10, 2006
  • May 10, 2006
I used a 3' length of 5/8 stainless steel tubing to run mine. I went to the auto parts store and rummaged thru the molded heater hose selection and bought a few different pieces. When I had the Air Gap intake, I had two tubes running front to back just about the length of the valve cover. I used a 90 degree molded hose to connect to the heater fitting on the intake and another molded to connect the other tube to the water pump. I used some plastic tube supports from these guys, http://www.made4uproducts.com/T-Clamps.htm and bent some aluminum strap to support them. I used intake manifold bolts to hold it in place. I had the heater box out of the car so it was easy to find molded hoses for the back connections to.
68RCodeConv
345
Houston, TX
May 10, 2006
  • May 10, 2006
I used a piece of copper tubing I got at Home Depot (plumbing section).
C
candy-a-Mach1
291
Kentucky
May 10, 2006
  • May 10, 2006
Let me know if you are interested in something like this. It uses two aluminum tubes, held apart by a plastic bracket. The A/C valve is optional.
http://forums.stangnet.com/showthread.php?t=529530
I can hook you up with aluminum tubing and formed hoses for half that price. I work for a company that makes 100 million of them a year. I agree: the old rubber hose accross the intake or strapped to the shock tower just didn't appeal to me either.
P
palerider94
573
  • May 11, 2006
That looks good! I'm going to try and clean up the old one - sanded and painted. It still has some slight pitting - If it leaks I will definitely very interested. thanks
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
