Heater hoses....
the short hoses run from the black tube thats screwed into the top of the intake to the actual hearter core itself on the firewall.
removing the upper intake shoulds help you get a better shot to hook them up with your fat hands.:D
you'd only be replacing the upper intake $10-$12. there are 6 bolts that hold the upper to the lower. 2 bolts in front 2 bolts, 2 under the plaque, 2 bolts in the rear.
you can reconnect the heater hoses without pulling the upper if you want to save your save a gasket, it's just easier pulling the upper and connect the hoses to the metal tube since you said you have big hands is the reason i suggested pulling the upper.
