Heater core's been shot for ages, been running a nice copper-tubing U-turn at the end of the stock hoses as a bypass. The heater pipe, itself, has begun to give up the ghost, now, and is getting a teeny tiny bit of seepage betwixt its upper and lower halves (right ahead of the front EGR spacer line fitting). My options: 1. Replace the heater pipe with a new one from 50resto.com and throw on a nice new U-bend hose at the back, or 2. Remove the whole heater pipe assembly, altogether, and relocate the coolant temp sensor to another happy home.
Okay, obvious problems are going to be where to stick the coolant temp sensor in lieu of its fitting in the heater pipe, what to do with the fittings for it coming off of the water pump, and what about the open hole on the intake manifold?
I was first thinking of just threading the coolant temp sensor right into the intake manifold, but I'm assuming I can't just dead-end that port, because that's either a main supply or return route for the coolant. That, and I'm sure the temp sensor doesn't even have the same thread size/pitch. So, maybe a standard pipe thread brass fitting with a barb end, going to a thick (5/8"?) hose that loops around back to the water pump?
Anyone deleted the heater pipe, completely? Or does everyone just run the good ol' ghetto-engineered U-shaped hose reroute kind of gig at the tail end?
