I posted this in the regional forums as well, but this gets more traffic, so here goes again.
Any Orlando / Kissimmee people PLEASE be on the lookout for my car.
My house was broken into earlier today and along with several thousand dollars worth of household electronics, jewelry, etc. they helped themselves to my car which was under a car cover in my garage.
It is a pristine DHG Bullitt with a 01 Cobra front fascia. It has 18" Wheel Replicas and plate # 2K1 6T8. This is a heavily modified vehicle that will not be easily replaced. Here are some pictures of it:
The police are (supposed to be) looking for it. If you happen to see it PLEASE call the Osceola County Sherriff's Office.
They took the cover along with my car so hopefully this means they will be taking care of it. Somehow I doubt this, however.
Here are the mods that have been done. This car is ONE of a kind, I doubt there is another on like this on the planet.
The mods this car has is as follows:
Engine
Kenne Bell 9 psi Intercooled Twin Screw Supercharger
SLP Long Tube 1 5/8” Headers
SLP X-pipe with Catalytic Converters
Borla 2.5" Catback
Accufab 75mm Throttle Body
Kenne Bell Big Tube Intake Kit
90mm MAF Sensor
36 lb/hr Fuel Injectors
Kenne Bell Cold-Air Kit
Kenne Bell Boost-a-pump
Kenne Bell Switch Chip
’03 Cobra Dual Fuel Pumps and Tank
’03 Cobra Radiator (2 Row Aluminum)
Moroso 7 qt. Oil Pan
Steeda Oil Catch Can
Deleted EGR System
Driveline
RPS Aluminum Flywheel
Centerforce Dual Friction Clutch Kit
Ford Racing Aluminum Driveshaft
Steeda Tri-ax Shifter
Ford 3.31 Ring and Pinion Gears
Ford Racing 31 Spline Limited Slip Differential
Moser 31 Spine Axles
Brakes
Powerslot Rotors
Hawk HPS Rear Pads
Stock Ford Front Pads
Goodridge Stainless Steel Braided Lines
Suspension
Ford Racing 1995 Mustang Cobra R Front and Rear Springs (700/850 lb/in (f), 200/260 lb/in®)
Tokico Illumina 5 Way Adjustable Shocks/Struts
Steeda HD Rear Sway Bar
Steeda Bump Steer Kit
Steeda X2 Ball Joints
Steeda Adjustable Rear Lower Control Arms
Steeda HD Upper Rear Control Arms
Steeda Camber/Caster Plates
Steeda Full Length Subframe Connectors
Kenny Brown Jacking Rails
Exterior
2001 Cobra Front Bumper Conversion
18x9, 18x10 WR Bullitt Wheels
Toyo T1S 275/35 18 F, 295/35 18R
Interior
Autometer Triple Gauge Pod
Autometer Z-Series Boost Gauge
Autometer Z-Series Fuel Pressure Gauge
Autometer Z-Series Oil Temp Gauge
Steeda Aluminum Shift Knob
Bazooka RS 10" Amplified Bass Tube
The police are looking for it. If you happen to see it PLEASE call the police at (407) 348-2222
Engine
Borla 2.5" Catback
90mm MAF Sensor
Deleted EGR System
Driveline
Brakes
Powerslot Rotors
Hawk HPS Rear Pads
Suspension
Exterior
Interior
