Hi guys, I know this is kinda out there, but I thought I would try anyways.....
I have a 1989 Probe GT (turbo) with ABS. The brake pedal is spungy and the rear brakes don't seem to be working much. I have replaced the master cylinder and it didn't help, still the same!
The ABS unit has it's own resevoir, seperate from the master cylinder. I have bench-bled the master and then I bled the right rear caliper followed by the left rear and then right front and lastly the left front. I did get some air out and now if I pump the brake pedal once it feels better, but they are still not right.
I don't undedtand the resevoir on the ABS unit.... Could that be my problem? Is that suppose to be bled somehow?
Any help would be appreciated!
Thanks, Matt.
PS, the ABS light is on and the ABS does not work.
The ABS unit has it's own resevoir, seperate from the master cylinder. I have bench-bled the master and then I bled the right rear caliper followed by the left rear and then right front and lastly the left front. I did get some air out and now if I pump the brake pedal once it feels better, but they are still not right.I don't undedtand the resevoir on the ABS unit.... Could that be my problem? Is that suppose to be bled somehow?
Thanks, Matt.
