HELP. 5.0 won't hold a charge
blbowers
I brain farted while jumping my 5.0 and reversed the cables like a dummy. Noticed smoke from the battery side (driver side) of the engine compartment and quickly disconnected. I replaced the battery and the alternator and the car does not hold a charge. It loses juice very quickly regardless if it is running or if it is off. I can jump it, but it loses juice so fast that it won't run longer than about 5 minutes before it dies. The entire electrical system is stock. Also checked + and - battery cables and they look good. Please help.
Thanks,
Brian
p.s.
I searched the forum, but found nobody was a dumb as me so no results.
Reversing the jumper cables usually takes out the alternator. It destroys one or more of the diodes inside the alternator. To check this out, look for 12 volts at the black/white wires on the back of the alternator. If the 12 volts is present, the altenator is toast. If it isn't, you may have opened up the alternator fuse link that lives inside the wiring harness near the starter solenoid.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for wiring help.
A 3G upgrade would be a good thing to do at this time. Here's websites with pictures of the 3G (94 Mustang and later 130 amp alt) installation procedure...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
See these sites for the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires may be overloaded to the point of catching fire and burning up the wiring harness.
