What were you trying to achieve with the parts you bought? How did decide these changes would achieve the goal you were after? How did you lower the car? Do you understand that when you lowered your car you traded traction for a preferred center of gravity? The center of mass didn't change except for the minor differences in the mass of the arms and shocks to coil overs. What you need to be aware of is if you set up the changes you've made to work like your old setup you've spent a lot of money to achieve nothing. What you've done has altered the weight transfer specs (COG) for your car and more than likely your front
suspension is rejecting your changes. When hot rodding around have you noticed more dive and oversteer around corners?
