Help, A/C compressor broke 0n 06 GT
boss 302
20
Yesterday as i pushed the A/c button, no cold air. It was working fine the day before. As i hit the button again, I heard a bang like a loose part had fallen off. I pulled over, raised the hood & found the clutch disc laying between the radiator & sway bar. The shaft broke & the splines are twisted. Do I need a new compressor or can the shaft be replaced? If I need a new one, wheres an inexpensive place to get one? Autozone doesn't have anything this new. Figures the warranty is expired. :(
If the shaft broke, you'll more than likely need a new compressor. There really is no such thing as a cheap compressor either, you're probably gonna wind up going with Ford.
Just wondering if this is a common problem. Living in the North East, It probably only got used 50 times. Strange thing was the break was clean but not shiny like a fresh break
