HELP!!!!!!!Antifreeze in my oil....
wat causes antifreeze to go into the oil.........i need help bad please....i dont know wat happen i took off the throttle body because i was gonna put a new one on but then decided not to.....and put it all back together and then lots of white exhaust was comen out.......so i checked the oil and theres antifreeze in it anyone that can help please reply im young and tryen to learn...thankz
If you still have your EGR intact and the coolant lines to it intact, a bad EGR gasket could be a source of coolant making it into the chambers (white smoke).
If a coolant line was accidentally connected to the oil filler nipple (PCV port), this would put coolant into the crankcase.
The following picture might help:
Thanks to S&2B's (site host).
For a super quick but very temporary fix (which could lead to possible pinging - keep an ear out):
Disconnect the and loop the two EGR coolant lines together (Be sure they're coolant lines). Be sure the remaining line from the TB to oil filler is just a vac line. Pressure test the cooling system and see what you see and hear what you hear.
Good luck.
I agree, put 2 and 2 together would indicate that if your motor had no smoke before and you removed the egr spacer and tb than a new gasket is in order. Replace the gasket and change your oil
Good luck.
