HELP brake issues after 5lug conversion, bled brakes 100+
old_blue
1,783
282
124
well maybe not 100 times but it sure feels like it. I took the master cylinder off last night and bench bled it. Today I bled the brakes the old fashion way. I didn't get a chance to test it yet due to a dead battery that wouldn't jump. Getting a new one tomorrow but i am pessimistic about it being ok. I have bled these brakes many times and the pedal is rock hard when I am done. Then I fire up the car and the pedal goes to the floor. The car stops but the pedal is on the floor. Any ideas? I am at a loss. I can't enjoy my mustang at all at it is pissing me off.
setup:
95 booster and M/C
96 rear disc
pbr fronts
wildwood prop valve (turned all the way for bleeding)
One thing that concerns me is when I was putting in the Booster the rod that goes into the M/C fell out. Is that normal?
Sounds like it might be a bad M/C, the adjustment rod should not have fallen out either as it is set very precise. You can read how to adjust the rod proper on Maximum Motorsports. You might want to snag a 93 Cobra Booster and M/C and be done with it!
old_blue said:
I am wondering on whether the booster rod should have just fallen out like it did. My fox one doesn't do that.
Yeah that should not have fallen out as it needs to be a precise length and you fine tune it by turning the small acorn nut on the end. Sounds like someone might have sold you some bad stuff, the 93 Cobra stuff is actually a better fit than the SN95.
thanks for the info. I will get a new booster from checkers and see if that alone will work. If not then I will get a new m/c as well. Although I think the m/c will be okay.
Did you get the 93 Cobra Booster installed yet, did it help?
