Help!! Burping
If your lower hose is cold then chances are either the stat is not opening or installed backwards.
Here is a diagram of how the coolant flows
attachment.php
OK I have a update I drained the coolant put lower hose on took off bleeding screw got a funnel poured in antifreeze then put coolant in bleeding hole but it came out the radiator fill hole plug bleeder started car but coolant just kept coming out top radiator I been working in 20 degree snow freezing rain put in about 12 hours change wires and plugs but I only had use one hand I'm about to drive me and my pony off a cliff
Before you take the big jump, take a breath,
You changed the lower radiator hose, why?
When you where filling up the radiator did you open the bleeder and let the air out as you filled the radiator?
When you say coolant came out of top of radiator do you mean the tank where the cap is?
OK tomorrow I'm going to drain it again now see if I got this remove bleeder valve fill radiator squeeze top hose put bleeder valve back on turn heat on high or low start car when warm top off overflow let cool check fluid
Fill the radiator with the bleeder screw open. Keep filling the radiator until a steady stream of antifreeze/coolant is coming out of the the bleeder. Close the bleeder and top off the radiator. Start the car and turn the heat on.
Edit: When you filled the car up with antifreeze,was it completely cold? Like had not been running all day? Did it puke antifreeze immediately after you filled and bled the cooling system ?
OK guys today was nice10 below. Wind chills I didn't drain everything I took cap off open bleeder found that a liter bottle work great for funnel so I put coolant in squeeze hose replaced bleeder bolt started car had heating on high funnel filled seen lots air bubbles one thing I noticed was top hose doesn't fill with water(stat) right I put 3 in. I watch suck all coolant down cabin get warm then cold let me hear opinions going bed early that cold zaps strength
yes sat24. Hrs and didn't bealch until it ran for a minute can I film send and have someone let me know if I'm f'ing up
