My 94GT has had a funny idle as of late. When it I shut down the car, and start it back up again while the car is hot, I notice the idle dips a little lower than usual sometimes, around 500RPM. It only does it when it is hot.
I disconnected the battery, removed the IAC, cleaned it with electric parts cleaner and installed it back on.
I connected the battery and started the car with the IAC unplugged via this article...
http://www.muscularmustangs.com/idlereset.php
The article says to set the idle with the throttle blade set screw until you get it where you want it, then plug the IAC plug back in.
Well, no matter where the throttle blade set screw is, I can't get the thing to idle under 1800RPM.
What is going on here? I can't drive like this...
Thanks guys!
Thanks guys!
