HElp Clutch is screwed
KT93LXVert
30
Auburn, AL
OK so i swaped the pedals outta my gt into the convert to get the clutch pedal. once the motor was in the car i tryed to crank it and the clutch will not disengage i took the tranny out and had someone under the car look and see if the cable was pulling it is but not enough. and i didnt put the spacer for the pedal assy becaus the one in the other car was the same. what is wrong with it? please help!
You might want to install an aftermarket (metal) quadrant and firewall adjuster. It could save future issues (when the stock pieces strip).
i agree, my 89 had to have a metal one cuz the plastic ones stripped every 3 or 4 months, a ford racing adjustable was only about $79 in '03, get it if your pressure plate and throw ou bearing aren't the problem...well worth it...
