Help, EEC4 won't give codes!
rd
3,316
63
109
Ocean Springs MS
My 89 Notch (2.3l) ran out of gas Wed, but had a stalling problem all week.
More gas got it to run, but the check engine light is on and it runs miserably.
I jumped the single pigtail connector to the upper right EEC4 connector, but I cannot get a check engine light flash with either the KOEO or engine running tests.
I seem to have 5.8 volts to ground at both the EEC 4 connector and the single connector.
This read ok with a code reader a couple months ago.
Any suggestions?
You have lost the sensor signal ground - black/white wire, pin 46 on the computer. With the power off, measure the resistance between the black/white wire on the self test connector and the negative post on the battery. You should get less than 1 ohm.
AutoZone wiring diagrams for Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
Thanks, jrichker!
Just checked it.
I have continuity from the EEC4 connector pin to all of the plugs on circuit 46, all the way back to the 60 pin connector pin.
I did not have any continuity to ground, or to the neg bat post.
I cleaned the ground by the EEC4 box. Did not help.
I swapped in my spare EEC4, and it fired up, ran much better, the MIL was still on, and when jumped, it started flashing codes.
At least now I have some chance of figuring out whats wrong.
Thanks again!
RD, FWIW, Ray III (mostly posts on the Corral) might have some input on wiring pins. He is fairly savvy with the 4 banger wiring as I recall. (There are many others, but he is the first one I thought of).
Good luck bud.
You had it right and saved my day, week, etc.
Circuit 46 on the 2.3 is the same thing, signal return. When I started, it had no continuity to the battery neg or any other ground from the EEC SIG RTN. I checked it, its the black w/white strip wire thats common to the MAP, TPS, EGR position sensor, and some other stuff, as well as the EEC4 test connector SIG RTN, upper right. ( the one you jump to get codes)
I had continuity between all of the connections in the harness, and back to the 60 pin connector in the harness. But none had a connection to the batt neg.
I swapped in another EEC4 that I got with my spare engine and trans, and I had continuity to ground from the SIG RTN, and it would flash codes on the check engine light. Finally!
I finally decided that it showed a code 22 and a code 84. 22 was no signal from the MAP, or out of range, 84 was EGR control solenoid.
I swapped in the MAP sensor from the harness that came with the spare engine, and the check engine light went out, and it ran just fine.
I finally reinstalled the other computer in the bracket, and it ran down the road fine.
Thanks, the circuit 46 info was great!!!!
