You were running on battery voltage and the load was dropping the voltage down to 9 volts.
Either the alternator died or the fuse link for the alternator burned up. The fuse link for
the alternator is a dark green wire up next to the starter solenoid.
Most auto parts stores will check the alternator for free on or off the car.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
If the fuse link didn't go bad, the alternator did. It is time for a 3G conversion. The 3G is a 130 amp alternator commonly used
on 94 and later 5.0 Mustangs. Mine came off a 94-95 Mustang.
Here's websites with pictures of the 3G installation...
See
http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm -
all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Use these sites for information on the right way to do the wiring. Some people will tell you
that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in
the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator.
If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point
of catching fire and burning up the wiring harness.
The secondary power ground is between the back of the intake manifold and the driver's
side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G alternator
needs a 4 gauge ground wire running from the block to the chassis ground where the battery
pigtail ground connects.
Electric fan = 3G alternator if you want long life & reliability from your car.
The electric fan saves some HP. The stock fan's parasitic drag runs from 7-12 HP depending on
who you talk to. The electric fan uses about 1/2 HP of power from the electrical system.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
See
WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length)
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
3/4 “ Black heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-058
3/4 “ Red heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-064
Pre-fab 4 gauge cables with lugs already on the ends are available in most auto parts stores.
Look for the starter switch to starter cables.
I am very careful to maintain backwards compatibility, so I did things a little different. The
white/black stator wire gets the insulation stripped back about 1 1/2" in the middle of the
wire & cut in the middle of the stripped area. Then a short length of white wire with a 1/4"
slip on female spade connector gets spliced on to the white/black wire. Slide on enough
1/4" heat shrink tubing on the white wire to cover the solder splice you are going to make.
Next all 3 wires get soldered together & the heat shrink tubing gets shrunk. When you finish,
the white/black wire looks like a "Y" with 1 white arm and 1 white/black arm. I left the
black/orange wires connected to the original plug and did not do anything to them. When you
are done, the original plug still has all the wires connected to it and they are still functional.
The extra white pigtail wire that you spliced, soldered in & covered with heat shrink tubing
is just long enough to plug into the 3G without much left over.
I ran the 4 gauge wire under the front of the engine next to the 4 gauge wire for the starter power feed.
It came up the same
path as the fuel injector supply lines, and gets bolted to the power output lug of the 3G alternator.
The 125 amp fuse is mounted on a plastic panel bolted to the stock ignition coil mounts.
One of side of the fuse has a 4 gauge wire connected to the battery side of the starter solenoid &
the other to the 4 gauge power feed wire for the alternator.
I had some 1" silicone aircraft heat shield tubing that I fed the 4 gauge alternator power
feed wire through and tie wrapped & clamped it in place with some aircraft cushion clamps.
That provided the wire extra protection from road debris and rocks. Some heater hose
could be used to do the same thing.
I have an additional 4 gauge ground running from the power steering pump mount to the
common chassis ground being pointed to in the photo.
Apart from the grinding I did on the mount bracket, there wasn't much to it. Rather than
just grind a notch, I ground the whole web back to the thick part of the bracket. It looks much
more factory that way.
