My battery had run down from the car sitting the other day, so i hooked up the charger to it. After about a day of charging I removed it. The car started up fine and the voltmeter was registering normal. Took the car out and the stero and such worked fine. As soon as i got to the nearest stoplight the car died as soon as I pushed the brake pedal in. It started right up but both the Speedo and the odometer no longer work. Now everytime I come to a complete stop (traffic light, parking, etc) the car dies. If the ignition is switched off and then the car is started up again the odometer comes back, but only until you brake fully again and then the car dies, along with the odometer.
I checked all the fuses that would pertain to instrument cluster or ABS but none of them are burned out. If anyone has any ideas, please let me know.
