help... having a surge demon problem...
  • Thread starter Thread starter BelueLX
  • Start date Start date Apr 16, 2004
BelueLX
1,195
  • Apr 16, 2004
My cars idle jumps between 600 and 1200rpm. Im running a C&L73mm MAF. When I unhook the MAF connector the car holds a solid 1200rpm idle and doesnt move. If I cut the idle any lower than 1200 the car will surge its way off. Any ideas if my MAF is bad or...? I dont have any codes or a check engine light with the MAF connected. Should I convert to a Univer blow-thru setup or will that solve any of my problems? Thanks,
Cody
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 16, 2004
  • Apr 16, 2004
Turn the MAF from 12:00 TO 3:00. Keep turning and you may ffind the sweet spot that doesn't surge.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Engine Surging idle only on start up
  • keel
  • Jun 18, 2024
4K
Fox 5.0 Mustang Tech Sep 14, 2025
keel
