help i have ignition problems
  • Thread starter Thread starter goliath669
  • Start date Start date Dec 31, 2006
G
goliath669
  • Dec 31, 2006
i have a 65 200 inline 6 and i replaced the coil but i still have no spark
the points are new and they are gapped properly but i still have no spark what could be wrong?
D
dgw8022
22
  • Dec 31, 2006
Have you checked to see if you have voltage going to the coil? Problem could be further back along the circuit.
G
goliath669
  • Jan 1, 2007
yes i have voltage to the coil my problem is i do not have any spark and i replaced the points and condensor gapped them to .034 and still nothing i am getting pretty frustrated
rbohm
6,698
550
204
tucson,az
Jan 1, 2007
  • Jan 1, 2007
check your plug wires for continuity.
G
goliath669
  • Jan 2, 2007
ok i as of today still have no spark i re gapped the points @ .025 per the manual and i am still not getting spark i am however getting voltage to the distributer but nothing past that
another question i have is the ceramic balast resistor that is on the car i replaced but where do the wires go how i have it now is from the positive side of the coil, to the resistor then from the resistor to the positive side of battery and the negative side of coil to the wire coming out of the distributer is this wrong? i am at wits end
M
madbrad
72
Albuquerque NM
Jan 3, 2007
  • Jan 3, 2007
When did the problem start? Were you replacing ignition parts then this problem started?
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Jan 3, 2007
  • Jan 3, 2007
MadBrad, Good Question!
M
mustangman1974
463
  • Jan 3, 2007
well I would check 2 things.
1. disconnect condensor and see if you have voltage in the points. be sure to wedge a popsicle stick between the points so you do not burn them.
2. hook up a spark plug wire and plug to your coil directly, bypass the cap and rotor. with the key on manually open and close points. does the plug spark. (remember the plug needs to be grounded and away from carb.
If you got voltage and spark w/o cap and rotor. then there is an issue with clearances inside your cap and rotor, or you forgot to put the rotor in like I have done many times under stress.
65Stang200
40
  • Jan 4, 2007
Indeed, I have forgotten to put the rotor back in too.
G
goliath669
#10
  • Jan 7, 2007
  • #10
well when i bought the car it wasnt running. i did replace the points and condensor, i wasnt changing anything and yes there is voltage to the distributer no voltage to coil i did try to check spark directly from coil and i still do not have it. i am going to buy another set of points and try it again i hope that this all works any other ideas ? i mean besides taking it to a shop?
rbohm
6,698
550
204
tucson,az
Jan 7, 2007
#11
  • Jan 7, 2007
  • #11
that is odd as power goes to the coil first, then to the dist. the points break the ground for the coil to allow the magnetic field to collapse thus inducing voltage through the secondary windings. it sounds like the coil is wired wrong. check your wiring. the power wire goes to the coil positive terminal, the the points are connected to the coil negative terminal.
G
goliath669
#12
  • Jan 12, 2007
  • #12
ahhhh thank you problem fixed thanks everyone for your help
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
  • brandyn200
  • Jun 20, 2026
AeroCoupe
