help---MAF
  • Thread starter Thread starter 306man
  • Start date Start date Sep 17, 2007
306man
17
denver,CO
Sep 17, 2007
  • Sep 17, 2007
Need help with the maf,, Car ran fine until i put the full mac exhaust system on about an hour later the mass air flow unit started pulling in so much air it barely idles and wants to die , with the maf making a big suction noise.... Any Ideas
vristang
4,933
101
124
Seattle
Sep 17, 2007
  • Sep 17, 2007
I have no idea...
Pull the diagnostic codes and let us know what you get...
KOEO & KOER (assuming it will run)
jason
306man
17
denver,CO
Sep 17, 2007
  • Sep 17, 2007
hey jason there is only one problem... I have nothing to find out what codes are coming up...
HISSIN50
34
129
Sep 17, 2007
  • Sep 17, 2007
See Jrichker's post on pulling codes with a hair-pin (I think Jason has a tech-note on his own site as well).
vristang
4,933
101
124
Seattle
Sep 17, 2007
  • Sep 17, 2007
Give this a try, if JRichker doesn't post something better...
http://www.troublecodes.net/Ford/
(I have had guys complain that it didn't work, but I've never done it this way myself, so I'm not sure. It's definately worth a try...)
The spreadsheet I have put together is freaking out, but there is some info on code readers here...
http://www.freewebs.com/vristang/eecivdiagnostics.htm
Let Us Know,
jason
306man
17
denver,CO
Sep 18, 2007
  • Sep 18, 2007
hey just to let you guys know, I just heard a rumor saying that I may have a plugged muffler or h-pipe so im gonna see what the deal is.... Get back to ya after I diconnect.... Thanks for trying to help me,, greatly appreciated....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 18, 2007
  • Sep 18, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
306man
17
denver,CO
Sep 18, 2007
  • Sep 18, 2007
well it wasnt the exhaust,, i wonder if the maf took a poop???? and i ordered that code reader
306man
17
denver,CO
Sep 18, 2007
  • Sep 18, 2007
the codes i recieved from counting the light are , 5131, 8182, 8584...
vristang
4,933
101
124
Seattle
Sep 18, 2007
#10
  • Sep 18, 2007
  • #10
lol
Try again...
The codes will be 2-digit...
F
facemelter71
60
cincy
Sep 20, 2007
#11
  • Sep 20, 2007
  • #11
Ive got an 89 notch,basic 5liter.E-cam electric fan,long tubes,off road H,flowmaster dumps.Stock computer,no tune,stock maf untill yesterday.Car ran fine when all installed.The exhaust i highly doubt will make your car wanna do that.But just in case,start the car and at least try to get it to idle so the comp can relearn itself.If not.Frisby the mass meter and replace.Dont buy some huge 90mm either,it wont work.just a 70 mm will be fine.
306man
17
denver,CO
Sep 20, 2007
#12
  • Sep 20, 2007
  • #12
ok cool... wondering if i buy the new maf will it come with the pluggin on top cause i want a new one just in case
306man
17
denver,CO
Sep 20, 2007
#13
  • Sep 20, 2007
  • #13
ok i can get the new sensor on top of maf to right... also wondering should i step up the injectors , they are stock... have a basic 306 with 190 160 heads and the cam is a f303, .512 lift..
F
Fox8950
247
Sep 20, 2007
#14
  • Sep 20, 2007
  • #14
Just out of curiosity did you unplug the neg. battery cable for a while to reset the comp? And with my old CAI (which I removed and went back to stock airbox) if you have one I know clocking (rotating) the MAF changed how it ran alot, I'm assuming because the sensor doesn't like taking readings from air coming off a curve like most the CAI kits are
306man
17
denver,CO
Sep 21, 2007
#15
  • Sep 21, 2007
  • #15
ok sounds good... i will try turning it in the morning with it running i will get back to you guys on that.... thanks..
306man
17
denver,CO
Sep 22, 2007
#16
  • Sep 22, 2007
  • #16
well it worked...lol.. turned the maf half way and cleared codes and it works.... thanks everyone for the info....
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Saturday at 1:52 PM
Fox 5.0 Mustang Tech Sunday at 7:26 PM
General karthief
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
