Help me build a combo
DmnStr8
NH
I have a set of ported gt40 irons that are clean and just about ready to go. I just need rockers for them. This winter I'm going to be working on saving for the rest of the h/c/i.
What are some combo's I could do and about what can I expect for performance. Was looking for low 13's are high 12's.
Right now I'm thinking. Cobra or TMOSS intake, 65mm TB, 76mm MAF, and then maybe a cam, or 1.7's or both depending on how money is. I'm on a tight budget so I really can't gio all out and most likely will be going used on most things.
Thanks
A ported Cobra, GT40, or Explorer intake with a 65mm TB and 76mm MAF will work with the heads. For a cam you'll have do some searching and or speak to a custom grinder. Cam selection should decide which rocker ratio to go with and not the other way around.
I keep being told that there are better cams then the e cam. But I know nothing about how to pick a cam. Where should i look to learn?
Thanks guys keep me coming. I need stuff to daydream about.
if it were me I'd leave stock cam in, and get an used explorer intake and leave it stock.(unported)...convert the 65mm tb from the explorer over and run it on your stang, maybe pick up a used 75mm pro m bullet mass air meter calibrated to your injectors, or find a good pair of cheap used #24's....... . And maybe stick on some 1.7 rockers if there was funds availble to do so. with your gear, if you have traction you should be in the high twelves all day long!
good luck
Jack
