Help me build a monster
  • Thread starter Thread starter mustangman70
  • Start date Start date Dec 1, 2005
  • 3
1 of 3 Next Last
M
mustangman70
1,235
St pete, Florida
Dec 1, 2005
  • Dec 1, 2005
Allright X-mas will be good this year...im going to pick up a low mile 351 windsor out of an 80's ranchero tomorrow. I was torn between goin either 347 or 408.....yeah cubes FTW lol....SO
WHAT do you recomend i get for this beast, i want this thing to be out right angry, BUT somewhat streetable...BTW...to me streetable means i can drive it to work if i wanted too, i want this thing to sound angy at idle with a nice lopey cam, i dont have power anything so its all good there.....BUT what would be a good combo? i will be spraying a good 200 shot or more on it...so im thinking 500-600 HP before the spray would make me happy
BTW can i use my headers from the 302? or should i just step it up and get new ones?
Im thinking big X cam (what cam)
AFR heads (205 or 185cc)
good forged stroker kit (CHP?)
Good intake (vic jr?)
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Dec 1, 2005
  • Dec 1, 2005
500 to 600 HP before a 200 shot? Is that even possible with a 351?
J
Jc69Stang
95
  • Dec 1, 2005
Get a cam like the TFS Stage 3 or similar, I run one like it and it is a nice cam for what you plan. AFR 205, 185 = too small for 408W, Step up and buy 1 3/4" headers, not sure who makes the best forged kit, but a Vic Jr is always a good choice, I run a Super Vic in my 426W.
Good Luck
M
mustangman70
1,235
St pete, Florida
Dec 1, 2005
  • Dec 1, 2005
Thanks man it should be fun...what sort of limits do you think this block might have?? i will probbly use a main girdle (a good one) and everything else..
wild70stang
317
  • Dec 1, 2005
STROKE IT. and bore it of course. you should definately get some new long tube headers. get a pertronix ignitor II, 9mm spark plug wires, beehive valve springs, edelbrock air gap intake, an edelbrock 700cfm carb, aluminum radiator and an electric fan.
M
mustangman70
1,235
St pete, Florida
Dec 1, 2005
  • Dec 1, 2005
I wont use an edelbrock carb again lol
I would LOVE to use the air gap intake, i love it on my 302, but with the windsor i will be spraying 200 or so and thats NOT GOOD with a dual plane intake
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 1, 2005
  • Dec 1, 2005
That will be pushing the block awfully hard. I think the limits on the windsors is 700hp. If you could afford it, a dart block would be the way to go for this amount of powe you want to produce. Go with the Victor Jr. or even the Super Vic if you go above AFR 205's. Single plane is better than dual plane period, especially in a big cube high hp application like that. I had an airgap and am updating to a Vic Jr. Intake.
M
mustangman70
1,235
St pete, Florida
Dec 1, 2005
  • Dec 1, 2005
No a dart block is WAY out of the question....maybe later down the road.....OK so maybe 450-500 before the spray would be a little easier then
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 1, 2005
  • Dec 1, 2005
80's Ranchero...don't think so. The last one was made in 1979!
M
mustangman70
1,235
St pete, Florida
Dec 1, 2005
#10
  • Dec 1, 2005
  • #10
LOL then thats the one...im a dumbass, he said it was from the last year of the rancheros or some ****
iskwezm
4,159
20
79
Rowland Heights,California
Dec 1, 2005
#11
  • Dec 1, 2005
  • #11
your "one bad ass ride for a 19 year old" will be bent in two before you know it.Your chassis will not handle the power,nor will it get to the ground.If you cant afford the Dart block,you surely cant afford the rest of the body/chassis stiffening that you will need.Just build a mild 400-450 HP engine and you will be a very quick street car.
SPEED COST MONEY!!!!!!!
jerry S
1,365
52.22N 5.12E
Dec 1, 2005
#12
  • Dec 1, 2005
  • #12
Please confirm you have at least $10,000 for this project.
jasonn
316
By Rochester MN
Dec 1, 2005
#13
  • Dec 1, 2005
  • #13
iskwezm is right. Better have everything else to match. Make sure car is structurally sound, then add at LEAST a set of GOOD frame connectors. This is what I have done to mine. Frame connectors, welded spring perches adj. front and rear shocks with 6 cyl springs and caltracks. VERY built c-4 with mild converter. 69 408c.i. windsor with vic jr heads, mild 10.5 comp. mild custom hyr. roller cam, perf. rpm intake, 1 5/8 headers. Drive it all over the place, very streetalble. Not the greatest for mileage but it put out 519hp and 532 ft/lbs. torque and ran 11.39 so far. Would be REAL fun with the right intake headers and carb. But trust me 400hp is more than people think. You would have LOTS of fun with that.
bnickel
5,640
lubbock, texas
Dec 1, 2005
#14
  • Dec 1, 2005
  • #14
exactly and IIRC you still have the stock 8" rear. correct? that 8" will go away past 350 to MAYBE 400 hp. after that it's toast and even it does live behind a 400hp stroker windsor for a while it won't last very long. you need to make sure the suspension and chassis are up to the task before you spend a single dime on a 500 hp stroker.
steel1212
1,180
Frankfort, Ky
Dec 1, 2005
#15
  • Dec 1, 2005
  • #15
Bigger block sell the 351 and drop in a stroked 460 with some big ol' heads and a victor and spray the crap out of it! Go over to corral.net and ask the same question in the big block section only ask about a 460. Also stiffen the Wazoo out of that chassis, I would hate to see a nice 70 get twisted like a pretzel
iskwezm
4,159
20
79
Dec 1, 2005
#16
  • Dec 1, 2005
  • #16
jasonn said:
......... but it put out 519hp and 532 ft/lbs. torque and ran 11.39 so far.
70vert
722
Bay Area, CA
Dec 1, 2005
#17
  • Dec 1, 2005
  • #17
Stiffness First!
Before you do anything else - and I want in the 450-500hp range too, but I am getting the chassis/suspension ready first, you NEED to:
1. Install GOOD subframes, as was mentioned. Your coupe should be one of the stiffest body styles, but that doesn't mean squat with all your HP. at a minimum, maybe TCP's crossbrace. At a maximum, cut into your floor and connect the two frame rails with basically another frame rail. And then think about a roll cage.
2. Might even want to think about this: Boss 302 shock tower kit. The Bosses made close to 500hp, and needed this, you might too:
https://www.pro-motorsports.com/store/product.asp?id=18
3. And this, Boss crossmember and maybe a bigger front sway.
4. I haven't even started talking about the rear. You need a panhard bar or watt's link to locate that rear axle in the chassis, and then a torque arm and/or underride traction bars. Override if you want to control braking wheel hop too.
I can't stress all this enough. When I was 19, with my tired 302, I got myself in enough trouble - I would be dead right now if I had that kind of power. Be careful with it, make sure it handles predictably with all that power you're planning on first . . . good luck and be careful.
69Rcode_Mach1
1,473
Dec 1, 2005
#18
  • Dec 1, 2005
  • #18
Yes this is very true I agree whole heartedly with this. I am definitely going to need some suspension work soon. With all this power and only 225's on 14inch rims my car won't grip for nothing. Then comes all the suspension work, and some rear discs. Even with wider meat out back, you need to have a stiff chassis otherwise damage will occur, and you won't ever feel the power of the car since the tail will just be all over the road.
G
gzminiz
200
Phoenix, AZ
Dec 1, 2005
#19
  • Dec 1, 2005
  • #19
I am curious about this. Are you talking about connecting the rear and front frame rail or the left and right side? I would have to assume the front and rear as I don't see how you would circumvent the trans tunnel. But I don't see how connecting the front to rear would give you that much better rigidity against torsion. The subframe connectors is what helps against torsion. It isn't a bad idea and neither is boxing the frame but not sure how this is a maximum. Maybe I am missing something? Just my 2 cents
10secgoal
2,801
San Diego
Dec 1, 2005
#20
  • Dec 1, 2005
  • #20
That's how I did it. I cut the floors about half way back or so and put the subframes front and back, side by side with the frames. It took a while for the first one and I only got one done the first day. After i finished it I took it home. Just pulling out of the driveway I noticed a HUGE difference with only one side done. I don't think at this point I need a cage at all with the power I have other than for safety and rules. My car doesn't twist at all.
  • 3
1 of 3 Next Last
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
Progress Thread Evolution of the 'Hudson Heap' plans (87 GT)
  • MadSquirrelTech
  • Jan 5, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 26, 2024
