Well free advice always being worth what you paid for it (note: thats nothing...
IMHO:
Any basic rebuild kit from a reputable manuf will be ok, but that being said talk to your machinist/builder because they usually have a manuf that they know and like (tolerances, fit, finish, etc... they know a particular brand, you would be foolish not to listen to their advice)
Now beyond that... (again in my opinion)
- There is no better intake for the money than the new edelbrock perf rpm. ( read p-e-r-i-o-d) Unless you have a blue thunder in you hand...but they are hella-spendy
- Avoid pop up pistons as they impeed the flame front, if you need compression mill the block to zero deck, or even minus ten... and mill the heads if thats still not enough, you need the squish to generate turbulance to avoid detonation and hot spots.
- Install an oil line from the guage port just above the oil filter that runs around to the port on the top of the back of the block, this feeds fresh high pressure oil to the rear mains that can sometimes get starved due to the lifter galley being fed first. This costs about 2-3 hrs and 15-20 bucks worth of hardware and protects your 2-3-4-5000 dollar investment.
- Try to get the compression up to 9-9.5:1. This is good and safe, but still yields good power.
- If you really want 350 ponies, get a stroker kit from SCAT they can be found for about 16-1700 from strokerkits.com, flatlander racing, chp, paw, etc... do a google for "351c stroker kit".
This will yield 383-390-408 inches and get you MOUNDS of torque due to the added displacement. (you were going to spend money to have the old parts resized, shotpeened, balanced, etc anyhow... these come all ready done) So think of the cost in that context...
- If you can save 1200 and want to bolt on 50hp + get a set of the edelbrock perf rpm heads (bare) they are like 1000 ea complete... spendy but nice. Just an idea... 50+ horses is 50+ horses...
Just .02 from the cheap seats.
Dave-
