DavidF
I am an AFR owner and highly recommend them. Not only for the Hp gain but for overall quality. I was a previous owner of Edelbrock heads and was not happy with their performance or the quality.
zenboy99 said:I've heard that the Trick Flow heads have a better spring package out of box compared the the AFR's. I'm pretty sure MM&FF said the same thing in their cylinder head test article
VIPERn94Five-0 said:over the time ive been here on Stangnet based on convos with Paul, and seeing other users on here, and a couple emails ive sent to Ed Curtis (runs FTI) ive been sold on the 165's or the 185's depending on plans....from the power numbers ive seen...the AFR heads combined with an FTI cam do not always produce the MOST power...but by far the most USABLE power...and that is the most important...its not how much you MAKE but how much can you USE....and ive seen AFR headed cars give broader power bands more than a few times.....
Anthony
clang5oh said:i wouldnt count brodix out. my opinion on them is they are the most underated 5.0 head. easily competes with afr.
Killercanary said:Jordan... wher ehave you been? I haven't seen you on here in a while, and I agree with your statements.
Canfiled used to be THE head for a serious setup, but they had a lot of issues with quality and what-not from what I hear and that's why they fell by the way side.
clang5oh said:i have 2 friends with 88 mustang gt's. holley systemax intakes 9lbs vortechs on both. one with the afr's and one with brodix. 1/4 mile times are slower with brodix but only by a couple 10ths of a second.
95snoozer said:personally I think I'm gonna save my money and do a GT40P setup after seeing some dynoes which are better than most all of the AFR/FTI setups on this forum.
plus I am on a budget
Imyourzero said:This is a perfect example of why dynos don't tell the whole story.
302yellow1995Cobra said:Snoozer, how many cubes is your motor anyways? i know you had changed the bottom end out.. Is it a 308 or bigger?
