help me decide
  • Thread starter Thread starter 85gt5.0
  • Start date Start date Feb 20, 2006
85gt5.0
12
Smolan, KS
Feb 20, 2006
  • Feb 20, 2006
im looking to get the most out of my car, but i need help on deciding on what i should do with it
1985 Ford Mustang GT, 302 HO, 5 spd
what type of heads should i go with?
would my E5TE heads work, since their milled .030 over?
might install a B303 cam, since a friend has 1 i can have
should i go w/ 3.73's or 4.10 gears? so it has the 7.5" axle
ill need a dual hump crossmember, but plan on going w/ BBK LT headers, off-road h-pipe, and different exhaust
what else should i do?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 20, 2006
  • Feb 20, 2006
Your expectation of the car really is the determining factor for what type of heads you should get, aside from the cost factor of course. You're probably seeing a very moderate gain with the milled heads, but from a performance standpoint, not enough to really feel a difference. Adding the "B" cam will net you more power; I just can't really offer a guess as to how much. Do the '85s have valve reliefs in their pistons? I don't remember, but I know the '86 didn't, so that would be a very big determining factor as to whether or not the cam will work well with your heads. Being milled, the valves are already closer to the pistons, and with the increased lift, you'll be looking at an increased possibility of piston to valve clearance issues. If funds are limited, check out some iron GT40, or GT40P heads for a good bang for the buck head. There's been plenty of guys running 12s on motor, using both heads, and they'll really be able to take more advantage of the B303 cam.
Now for the rear end, I'd really recommend picking up an 8.8 rear. Yours could last under the mods you have in store, or it could be the weakest link in your drivetrain. I'm not really the best with choosing gears based on combinations, so I'll let someone else chime in here at this point. Good luck!
85gt5.0
12
Smolan, KS
Feb 20, 2006
  • Feb 20, 2006
o i definately plan on swapping the rear end to a 8.8, since ill be doing a 408 stroker, and TK0 500/600
I
IntenseBlue
946
  • Feb 20, 2006
Is it gonna be a daily driver, street/strip, track only?
85gt5.0
12
Smolan, KS
Feb 20, 2006
  • Feb 20, 2006
street/strip...wanting to get roughly 400 rwhp & tq out of it maybe w/ some nitrous
I
IntenseBlue
946
  • Feb 20, 2006
I'd get some AFR 185s, 4.10s, and a custom cam. E5s arent worth ****. You'll also need an intake. TFS Track Heat, Edelbrock RPM or RPM II, or Holley Systemax come to mind. I'd probably do the RPM II.
85gt5.0
12
Smolan, KS
Feb 20, 2006
  • Feb 20, 2006
what about the edelbrock air-gap?
I
IntenseBlue
946
  • Feb 20, 2006
Crap. Forgot you were carbureted. Yeah, I'd get an Edelbrock RPM Air Gap.
85gt5.0
12
Smolan, KS
Feb 20, 2006
  • Feb 20, 2006
would a holley 600 cfm work?
I
IntenseBlue
946
#10
  • Feb 20, 2006
  • #10
Yes.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
