First let me say thank you all for the advice and crits on this long project. I am trying to finish it up and need to ask a few more questions... I really want to drive it soon...
1. I am going to route the power steering under the lower control arm, because there just is not enough room to go beside the header. Question: Where do I get a pressure side line that is pre made to go under the arm? The original line takes a turn up beside the engine. Unbent would also be fine, as I have a bender for the hard line.
See previous thread: http://forums.stangnet.com/showthread.php?t=604143&highlight=power+steering
2. I removed the old foot pump and bottle (broken/leaked) for the window washer and will put in a switch and a new bottle with an electric pump on it. Question: Has anyone done this swap and if so, how did you do the wiring?
3. I will have to drive it in primer for a few months before I can do the paint. Question in two parts: What is the best primer to use if I am going to drive it; I have a gallon of Omni in the basement, will that work? (part two)- Am I just wasting my time doing a ton of prep work on the car to then have to do it all over again when I want to paint it?
4. What is it like to drive your cars, because I have forgotten!!!!
Soon, very soon!! Thanks all for your help over the past year.
I like driving it too much to take it apart
