Hey Hissin -or any other cooling gurus-
I just installed an ebay alum rad last weekend, already have a edelbrock water pump, and a Black magic extreme e-fan. So today on the way home at about 5:30 it's still 110* out, and after sitting in traffic then some 65 mph driving on the 60, then another 15 minutes of stop and go traffic, I get home just as my autometer temp gauge reaches about 245. This is with trick flow heads which makes me nervous. This is all without even turning the a/c on. I knew if I turned it on it would just be too much and overheat.
Why? so tonight I installed a 180 t-stat. It's just an autozone special, so it might not be balanced like I read in your other posts like the Mr. Gasket unit.
Well tomorrow will be the ultimate test. If it still gets just as hot as today I will get the pressure tester and test the cooling system.
Do you think I might have a head gasket leak? Should I look into the Taurus fan and dump the Flexalite? (haven't been impressed with it).
What exactly is your cooling set-up? Sounds like you have it dialed in and this is my daily driver which is driving me nuts 'cause I can't use the a/c I just shelled out over $300 to get charged!
all the goods are in my sig
Thanks
Thanks
