  • SN95 4.6L Mustang Tech
Help me out. Code P0125. Coolant temp.
  • Thread starter Thread starter Skidzz
  • Start date Start date Dec 15, 2006
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 15, 2006
  • Dec 15, 2006
The other day my CEL came on. It threw a code P0125: Closed Loop Fuel Control, Insufficient Coolant Temperature. I had it scanned at Advance. They said I needed to replace my coolant temperature sensor. So I bought one and changed it out. The CEL went off immediately, for a few days, but today, it came on again. Advance scanned it again, same damn code. Now they are saying that maybe my coolant is not reaching proper operating temperature. I HAVE noticed that my gauge reads quite a bit cooler lately than it used to. I know that the stock gauges suck, but it's a significant difference. I'm not sure if my coolant/water mixture is bad or if its a bad thermostat, or what. I'm thinking about flushing the coolant to start off. What do you guys think? Any ideas?
jstreet0204
939
Winston Salem, NC
Dec 15, 2006
  • Dec 15, 2006
Make sure your thermostat is opening. Take it out and drop it in a pot of water on the stove. use a thermometer, and heat the water, note what temp it starts to open up at.
Rickey_Bobby
332
Sarasota, FL
Dec 15, 2006
  • Dec 15, 2006
if it wasnt opening, it would overheat. If it is stuck open, the car would run cold.
Did you remove your thermostat?
Either way, Drop the $5 and get a new one.
jstreet0204
939
Winston Salem, NC
Dec 15, 2006
  • Dec 15, 2006
You are right, I don't know what I was thinking ( loaded up on cold meds today). I should have said, check to see if it is stuck open.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 15, 2006
  • Dec 15, 2006
Yea I don't have time to let the car cool down before it gets dark. I won't have enough time to after work tomorrow either. I hate this sunset at 5:30 PM crap. I'll have to buy a new stat and some coolant tomorrow, and I'll make a day of it on Sunday. Fun-fun.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 15, 2006
  • Dec 15, 2006
Oh, I also noticed that once in a while, I hear this "click" sound from the engine. There's no pattern or anything to it, it just randomly clicks once in a while. I don't think it was doing that before the CEL came on.
Rickey_Bobby
332
Sarasota, FL
Dec 15, 2006
  • Dec 15, 2006
you abviously like your car.... over time, you will become parinoid and "hear" things...
...little things here and there....
and then your brain will take over and go into the "what if" mode...
like "what if that click was a piston ring falling off.... or a broken valve, or a melted flux capacitor...
soon, you will have 100's of little sounds that scare you.
there is a solution to all of them...
Remove mufflers and get some subs...
Barrier
155
  • Dec 15, 2006
Tstat = 10 minute change Don't even need to add coolant if you raise the hose up quick enough
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Dec 15, 2006
  • Dec 15, 2006
Rickey_Bobby said:
...or a melted flux capacitor...
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Engine how fast would an engine overheat with zero coolant
  • dqureshi06
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 8, 2024
Mustang5L5
